Code 9
Old Feb 4, 2006 | 10:02 AM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Default Code 9
Im still throwing a Code 9 on my ECU for 92 Prelude, I thought i was throwing a code 9 because my distributor was burnt out, but i put on a "new" one but i still have the same trouble code. HELP PLEASE!!!!!!
Old Feb 6, 2006 | 11:08 AM
sgsoccerplaya's Avatar
sgsoccerplaya
code 9 is for a cylinder sensor. don't know if that means anything to you but you can check it out here http://www.92lude.com/self_diagnostic_codes.htm
Old Feb 6, 2006 | 11:55 AM
asheylarry's Avatar
asheylarry
the tests are continuity tests and you will need a service manual. the code is a tdc/crank/cyl sensor circuit. if all wiring is good, and you've put a new dist. in, try changing the ecu out for a known good one.
Old Feb 16, 2006 | 08:42 AM
stereo's Avatar
stereo
if the connections are good and you replaced the dizzyand still have the same problem ,check your timing belt sometimes if it jumps a tooth it will cause this code.
Old Feb 16, 2006 | 08:51 AM
F22B Prelude
Rachel Bilson
The timing belt is fine, im gonna have to take it in and get it checked again for timing, i was also told if the injector was stuck it would also throw this code, so ill just take it in and see if its fixed.
