Honda Turbo Problem (wrong forum but need help anyways!)
Old Jan 27, 2006 | 11:06 PM
Azndude1983's Avatar
Azndude1983
Default Honda Turbo Problem (wrong forum but need help anyways!)
01 Accord Turbo Lag????
I just installed the T3/t4 Hybrid Greddy turbo kit for the past three days on my Accord 01, 4cyl and everything looked straight to me. I tried to test drive it to see any leaking with slow speed first, but when I step a little heavier on the gas peddle to about 50-55 mph there is a lost speed in my car and there's a weard noise. It sounded like there's not enough air. .Does anybody knows what's going on?? Or does it have to do with the Vacuum Sources? About the Vacuum sources, i connect the Vacuum source from the BOV together with the Wastegate Vacuum source and used a T fitting and connect them to the engine Vacuum Source (IS that a good idea?) or sperate them to diff vacuum sources. There's a nipple on the Turbo and I was going to connect the Vacuum Source from the Wastegate to it but decided NOT. Well, i 'll try to mess with it again but IF anyone knows what's going on with it, please give some advise cause it doesn't sound and perform right when i increase the power. I have pictures but working on how to put them up here. (P>S) The BOV doesn't make that "psshhhh" sound like other's people BOVs do.. I talked to some guy and he said that's a Turbo lag and it happened to alot of turbo car, but he didn't tell me what's the problem is and what is lag? Also, someguy thinks that the turbo may not running or pushing any air into the intake but I've checked to see if there's a leak on the Pipes or if the turbo is running or not and everything was working right...Still don't know what's going on.
Old Jan 28, 2006 | 05:58 AM
flyromeo3's Avatar
flyromeo3
dork
Old Jan 28, 2006 | 06:32 AM
97civicEXVTEC's Avatar
97civicEXVTEC
how many threads are you going to make?
Old Jan 28, 2006 | 05:36 PM
boosted lude's Avatar
boosted lude
Sounds like you should do some research on turbocharging before you jump into a project like that... Not to be a dick but ive seen alot of motors blown because ppl don't know what they are getting into... search
