ok a lude 3rd g and it had a cluch problem it would smashh but when cold but after a wile that it was running it satrting slipen . so i change for a new sreet porformence cluch kit and it did the same thing ... why???
if u could help it wiil be usefull ..thanks
no the fly wheel was ok . and its not a cable cluch it hydrulic pumpd
THE FLYWHEEL IS NOT OKAY, UNLESS YOU HAD IT RESURFACED, IT IS SUPPOSED TO HAVE A MACHINED SURFACE, LITTLE GROOVES CUT IN THE METAL, SO THAT IT WILL MAKE A GOOD CONTACT. THEY MAKE SURE THAT IT IS PERFECTLY FLAT.
