cold air intake
Old Jan 12, 2006 | 09:54 PM
guidosv-tech's Avatar
guidosv-tech
Default cold air intake
okay i just purchased a cold air intake it came with a blow out valve? what is this where does it go and do i need it for the cold air intake to work also i have a little black hose that was connected to my air intake "stock" it was on top what is that for do i need to plug that in to my new cold air? plzz help as i am going to be installing this new upgrade tomorrow. thank you .
Old Jan 12, 2006 | 11:36 PM
bb4jdmlude's Avatar
bb4jdmlude
H22A
what kind of cold air intake did you buy? second it is a blow off valve. the black hose connect it to the little nub on the side of your intake to your block where the stock one was. the best idea is to just take them both off and put breather filters where the hoses connected.
Old Jan 13, 2006 | 06:34 AM
mwprs37's Avatar
mwprs37
uh...where the hell did you buy a CAI with a BOV? Its pointless to use...if you just want the sound of the BOV thats retarded...it wont work, the intake works on a vacuum when not boosted so there will be no air to "blow off"
There should be a hose that goes from your valve cover to your intake piping, thats it...pics would help to explain what hose you are talking about....
Old Jan 13, 2006 | 08:57 AM
2legit2quit's Avatar
2legit2quit
You Big Dummy
There should also be a vaccum hose that connects to the intake pipe. Generic intakes usually don't have a spot for it though.
Old Jan 13, 2006 | 05:03 PM
guidosv-tech
what is that vaccum hose for? do i need to have it installed?i sis it without i really didnt notice that much of a diffrence by not conecting that vacum hose will i lose some horses?
Old Jan 14, 2006 | 05:20 PM
guidosv-tech
Old Jan 15, 2006 | 03:18 PM
2legit2quit
You Big Dummy
It won't hurt anything.
Old Jan 17, 2006 | 04:27 PM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
the vacummn hose is for blow-bi
and yes u need it installed
ur OEM intake has one for a reason
Old Jan 18, 2006 | 08:33 AM
2legit2quit
You Big Dummy
O.K. there is two hoses that are connected to the stock intake. One is fairly large and goes from the valve cover to the intake pipe. The second one is a regular little black vaccum hose that is about 2.5 inches long and leads to the intake manifold. My brother has not had that hooked up to his intake for a few years now and there has been no effect. Of course it's there for a reason, but you car will run fine without it connected.
Old Jan 18, 2006 | 12:00 PM
mugenbb6's Avatar
mugenbb6
Haha BOV. its a PCV Valve from the intake to the valve cover.. sucks blow by gases jus like the other guy said
