cold start
Old Jan 1, 2006 | 06:52 AM
elton_hsu's Avatar
elton_hsu
Default cold start
what could be the problem if my prelude sounds a little hesitated at cold start? my starter sounds working fine, but if the car is warmed, there's no hesitation if i restart it again. does anyone know anything about this?
Old Jan 1, 2006 | 08:33 AM
hidewai's Avatar
hidewai
I had the same issue,after the first start then it's fine later.I change the fuel pump, fuel filter,engine coolent temperature sensor,and i added cold start fuel treatment to the gas tank ,eventually no result.
Old Jan 1, 2006 | 07:33 PM
mikesta21's Avatar
mikesta21
93preludesi
ya mine cranks a little longer than it should the first time and only time, but i think that inevitable with the harsh winters we have here.
Old Jan 2, 2006 | 11:31 PM
elton_hsu's Avatar
elton_hsu
where are u from?
Old Jan 3, 2006 | 07:05 PM
mikesta21's Avatar
mikesta21
93preludesi
boston
Old Jan 4, 2006 | 09:07 AM
elton_hsu's Avatar
elton_hsu
coldie coldie...
my mechanics sprayed some intake cleaner, and it does eliminate the rough cold start. but not completely though....
Old Jan 6, 2006 | 08:44 AM
elton_hsu's Avatar
elton_hsu
actually spraying the cleaner doesn't change it much. the lazy start-up is still there....is there any way to restore it?
Old Jan 17, 2006 | 11:47 PM
hidewai's Avatar
hidewai
this is the prelude site,i think 80 percent owner has this common issue,because i own three prelude before and all has this shit .anyone has fix it please post thanks.
Old Jan 18, 2006 | 01:06 AM
yaaiyaai's Avatar
yaaiyaai
my prelude hesitated to start during warm engine, cold no problem. replace the PGM F1 main relay solved the problem 100%.
although your problem is some how different from mine, i still suspect it is the PGM F1 main relay at fault, it does not work smoothly during different temperature.
you need to replace the PGM F1 main relay under dash. please check the
electrical component locator in the service menu.
it's cheap, so, worth a try.
Old Jan 18, 2006 | 07:24 PM
hidewai's Avatar
hidewai
I will give it a try soon.
