did any one do any engine build-up where it can rev to like 8500-9000 and stand 20-25 psi? And where can i find a good turbo kit and engine internals including cams,pistons,heads the whole deal. Thanks
THATPRELUDEGUY
09-14-2002 02:58 AM
The H22 is not the motor to run past the rev limiter from all I've read. No real power gains are going to be made and you have a good chance at cracking a cylinder or throwing a rod. As for turbo's running 20-25psi that's a custom deal with a ton of motor work involved, better get a good tuner to do that unless you want to replace short blocks once a week.
dptkfil
09-14-2002 10:18 AM
Re: Engine build-up
Originally posted by szm426 did any one do any engine build-up where it can rev to like 8500-9000 and stand 20-25 psi? And where can i find a good turbo kit and engine internals including cams,pistons,heads the whole deal. Thanks
The engine build-up will cost something near 9000 .. You can rev up to 10,000 rpm but I dont' suggest you do that maybe 9300... Just look at my setup ... You will need low compression pistons(mine is high because I want my car to be able to on street), rods, P&P, Crank, the complete head--valves, valves spring, retainers, cam and P&P..I will recommand to blue print your engine if you have the money.....My setup can stand 28 psi that boost by a T60...
SGImport
09-14-2002 10:19 AM
when do you hit full boost and what do you rev to?
dptkfil
09-15-2002 09:50 AM
Originally posted by SGImport when do you hit full boost and what do you rev to?
My car is still in the process of the a new paint job then it will ship to my friend's shop to complete the turbo setup... At this point, I really can't tell you.. but my buddy told me that I should see full boost like at 4500...and I can rev to 95k....
