How to (DIY)..plz help
Old Nov 16, 2005 | 03:18 PM
loodboi's Avatar
loodboi
هونده بريلود
Default How to (DIY)..plz help
What steps do you guys use when painting the housing of the 5gen headlights into black? plz any DIY thread??
Thanks..
Old Nov 16, 2005 | 09:54 PM
Mkazm83's Avatar
Mkazm83
Snapping bolts
Take them off the car
Warm up the oven to 200 degrees farenheit (celcious is going to be different)
TURN THE OVEN OFF, place a towel so the light isint resting on the rack
put the light in for a few minutes, checkin on it occasionally to make sure its ok
take the light out and try to try it apart with a flathead scredriver.
Once you have it apart its easy, take the peice out and paint to your likeing
Now its time to ut it back together, just put it in for 225 farenheit for a few minutes untill the black athesive gets tacky
stick the peices back together as hard as you can to make a good seal.
if you want run a bead of silicone around the lights to make sure they are weather sealed. Let me know if you have any more questions.
Old Nov 17, 2005 | 10:17 AM
2legit2quit's Avatar
2legit2quit
You Big Dummy
Yup, that's how it's done. Slow and steady when prying the lense apart, you don't want it to crack. G/L
Old Nov 17, 2005 | 11:07 AM
loodboi's Avatar
loodboi
هونده بريلود
Thanks guys!
Old Nov 20, 2005 | 02:28 PM
loodboi's Avatar
loodboi
هونده بريلود
One last questions, how do I remove the headlamps for modification. Were are all the screws located..
Old Nov 23, 2005 | 11:22 AM
loodboi's Avatar
loodboi
هونده بريلود
PLEASE can anyone tell me were all the "screws" for the headlamps are? I have to remove the headlights and would love to know how..
n00b question i know...h:
Old Nov 23, 2005 | 09:34 PM
FooD2000's Avatar
FooD2000
Still Water
you really need to just look and see. Go and start unscrewing, you really can't mess anything up.
