ABS light wount go away
Old Oct 31, 2005 | 06:39 PM
jdm-power's Avatar
jdm-power
Default ABS light wount go away
what can the problem be????
Old Oct 31, 2005 | 07:06 PM
Mkazm83's Avatar
Mkazm83
Snapping bolts
Check you brake fluid resevoir to verify that you have enough brake fluid.
Old Oct 31, 2005 | 07:19 PM
prelude1897's Avatar
prelude1897
Try just reseting the computer by disconnecting your negative battery wire for about 15min. then reconnect it, and if it comes back on, then you may have a messed up sensor. Have you messed with your brakes or suspension lately?
Old Nov 1, 2005 | 05:18 AM
jdm-power's Avatar
jdm-power
brake fluid is normal....
havent messed with my brakes or the suspension
it does need new pads though but i dont think that would make a difference with the ABS unit
il try to reset the computer today and let ya know what happens...
Old Nov 1, 2005 | 06:27 AM
pr1mo_13's Avatar
pr1mo_13
it may be the abs sensor at one of the wheels. possibly a bitche dup connector. My friend had an abs light and we later found that the rear right connector got disconnected somehow
Old Nov 1, 2005 | 08:18 AM
jdm-power's Avatar
jdm-power
wherez da ABS sensors located>>>??
