95 lude timing belt Broke!?!?!?
Old Oct 14, 2005 | 02:30 PM
jlh81's Avatar
jlh81
Default 95 lude timing belt Broke!?!?!?
I tried to search it but i just couldn't find it.
Does anyone know if the timing belt breaks does it fuck up the motor on the 95 si preludes? Or does you have any good links on showing the changing process?
Thanks
Old Oct 14, 2005 | 02:50 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Default Fucked?
If the timing belt breaks on any car its bad news, what was your RPM range when it broke, anything higher than maybe about 3k will cost you a new head
Old Oct 14, 2005 | 03:13 PM
fastball's Avatar
fastball
A little chin music
From: Cleveland, Ohio - Rock 'n Roll capitol of the World
All Preludes have interferrence engines - you need to have your car towed to your mechanic so he can pull the head and check for valve damage.
Sorry for the bad news.
Old Oct 14, 2005 | 07:22 PM
VPUPPY's Avatar
VPUPPY
a few ppl have been luck not to cause any significant damage. as suggested, pull the head and see what happened. what you could also do, replace the belt and then do a compression check to check for any bent valves.
Old Oct 15, 2005 | 11:47 PM
Phateless's Avatar
Phateless
S2K compatible
better safe than sorry. just spend the $$$ and change your timing belt and you're good for 90k miles
Old Oct 16, 2005 | 01:27 AM
jlh81's Avatar
jlh81
Default Shit
Thanks for the good info guys! Shit i was only cruising about 30 mph But my rpms were low when it broke. So i think im just gonna change the belt and cross my fingers.
Thanks fellas
Old Oct 16, 2005 | 03:38 AM
fastball's Avatar
fastball
A little chin music
Thanks fellas
You better check the head first..... if the valves are bent and you try to start it with a brand new belt, you may snap the brand new belt, or cause even more damge to your engine!
Old Oct 16, 2005 | 05:19 AM
VPUPPY's Avatar
VPUPPY
werd. like i said, since your going to just change the belt, make sure you do a compression check before you start it. even if you have bent valve, your engine probably wont run.
Old Oct 16, 2005 | 06:09 PM
jlh81's Avatar
jlh81
Shit that would suck ass if i put it on then broke it again. Yeah your right! Do it right the first time and save the hassle in the long run.
