wierd idling problem when driving
Old Sep 28, 2005 | 01:59 AM
preludedriva's Avatar
preludedriva
Default wierd idling problem when driving
ok when im driving around and im about to come near a stop or whatever i put it into neutral and the rpms "should" goto like 700-1000 or w/e right? instead it revs up to 3000 how do i fix this? kinda like a sticky idle
really annoying
i was told it could be iacv or throttle body?
if anyone knows a fix let me know thanks
Old Sep 28, 2005 | 10:27 AM
preludeH22a's Avatar
preludeH22a
i'm pretty much awesome
my car used to do that too. there's a valve right under the throttle body, i think it's called the FITV or fast idle thermo valve, take off the intake and inside the throttle body on the left, there are 2 ports. put your finger over the bottom one, and if it idles normally when its covered then it's the FITV. i took mine apart and put it back together and it was fine.
Old Sep 28, 2005 | 10:52 AM
preludedriva
so take off the intake cover the hole drive around see if it does it anymore? it only happens when i drive the car and put it into neutral
Old Sep 28, 2005 | 07:48 PM
preludeH22a
ah i'm sorry. i didnt realize it ONLY did it then. mine did it until it warmed up and then it still idled high. sorry bout that.
Old Sep 28, 2005 | 11:35 PM
preludedriva
damnit lol
anyone else know?
Old Oct 7, 2005 | 06:19 AM
MeStIzO's Avatar
MeStIzO
Default idle surge
i juss got finished with a jdm h22a swap into my 96 lude, lovin every minute of it, but when the engine warmed up i had an idle surge that kept jumpin from 700 rpms to 1400 rpms...i would turn on the AC and it would stop so i did some research and thought it was my IAC valve (idle air control) so i took that off and cleaned it with carb cleaner....it helped a little but it was still doin it. So my next step was to try the IAS (Idle air screw) its located right under the throttlebody on the passenger side i took a flathead and adjusted it clockwise and it brought my idle down to 900 rpms and never surged again...try it and let me know wus good....
Old Oct 7, 2005 | 09:50 AM
preludedriva
i get my car back tommorrow ill see if it still does it
thanks
