Help check engine light always comes on.
Old Aug 24, 2005 | 10:46 AM
jesseunvoas's Avatar
jesseunvoas
preludedriver99 you said you worked for honda will this void waranty?
also do you have pictures or know of a site that has a walkthough on how to fix the cel
Old Aug 24, 2005 | 11:40 AM
Ohio99Lude's Avatar
Ohio99Lude
I have used both methods and if you have an autozone around you it is easier in my opinion. Never had a problem with hooking it up to their reader. Anyways, the paperclip/wire method will not void the warranty. If you search around the Internet there are step by step walkthrus on how to pull the code and what the code means.
Old Aug 24, 2005 | 02:06 PM
jesseunvoas
does any one know a link to a site that gives details on doing the paperclip/wire method
Old Aug 24, 2005 | 04:22 PM
Mkazm83's Avatar
Mkazm83
Snapping bolts
Here you go,
http://www.superhonda.com/forum/show...hreadid=144813
Old Aug 25, 2005 | 08:01 AM
jesseunvoas
i found this site http://www.ntpog.org/mods/fifth-afc/ecu.shtml
and was wondering if this seems wise to do?
Old Aug 25, 2005 | 04:24 PM
Mkazm83's Avatar
Mkazm83
Snapping bolts
Did you find out why your car was throwing the check engine light?
Old Aug 26, 2005 | 05:55 AM
jesseunvoas
i had the egr removed so i figured it most likely would be that also i put on a gutted cat so most likely those two.
