HELP ME ! Plz *Wiring prob*
Old Aug 14, 2005 | 11:59 AM
chad4089's Avatar
chad4089
Default HELP ME ! Plz *Wiring prob*
ok i took out my radio so i could put a cd player in and now my turn signals {blinkers} wont work. soo.. did i cut a wire that was for my blinkers ..... if so what color wire would it be..... im such a dumbass..
Old Aug 14, 2005 | 03:41 PM
VPUPPY's Avatar
VPUPPY
did you cut your factory harness? did you check the fuses?
Old Aug 19, 2005 | 02:34 PM
Jos3ph's Avatar
Jos3ph
Same thing happened to me when i was messing around with the radio wiring harness. Apparently i blew a fuse when the power wire touched the chassis of the car while it was running. Check your fuse box for any blown fuses.
Old Aug 19, 2005 | 05:13 PM
tonysstudio's Avatar
tonysstudio
did you unplug the hazzard button? you blinkers and such will NOT work if that is not plugged in. Check that. other than that, must be a fuse i would guess.
