91 Lude B21 Rebuild
Old Jun 26, 2005 | 01:35 AM
diamondsleeper's Avatar
diamondsleeper
1990 & 1991 Si 2.05
Default 91 Lude B21 Rebuild
I've done serveral searchs and am aware of the problems associated with rebuilding the B21 as far as the cyclinder walls/rings issue. Most of the information deals with just getting away from the B21. I am looking for someone who has had success and experience rebuilding this engine. I would like to keep my 91 lude all original so I am determined to rebuild the B21 right. One question that comes to mind is. When you bore this block is the FRM on the cylinders still present? How thick is this material? I realize this is not the best design created by honda but this engine has made it 220k and the oil consumption still is about what you'd expect from a engine with that many miles on it. About a quart every 700 miles and some of that is due to a small leak at the oil pan gasket. I am not convinced its a lemon. I believe however that extra care must be taken to re-establish what was there from the factory due to this touchy design. If there is anyone out there who has had success with this engine I would like to know what kind of parts you used. Were they factory pistons/rings/bearings or were they after market parts? Did you buy a short block or rebuild it yourself? Did you bore it or just re-ring it? If you had it bored was the FRM still there to deal with or not? Any insight would be greatly appreciated. Thanks
Old Jun 26, 2005 | 05:51 AM
gingas's Avatar
gingas
I would try to convert a H23 or H22. I dont think you would be satisfied w/ the power of the B21 or try a B16.
Old Jun 26, 2005 | 08:13 AM
kenton's Avatar
kenton
Change sig? Lose [quote]!
It's really hard to convert a Pre-93 Prelude to H series.
Old Jun 26, 2005 | 08:58 AM
bigt61's Avatar
bigt61
WHy not just get a JDM B20-A. It is the same as your B21- just from japan with low miles on it. it will drop directly in. It will not have the FRM issues that your B21 will have. Your B21 will have issues even if you rebuild it. I know- I've owned 88-91 preludes so I'm talking from experience. try another website specifically for 88-91 preludes.
www.preludepower.com
Old Jun 27, 2005 | 03:10 AM
diamondsleeper
1990 & 1991 Si 2.05
Thank you for the insight. It seems still nobody is willing to give the B21 the time of day. I respect your experience bigt61. I really don't understand how it can be such a lemon if it's already made it 220K with virturally no problems at all. Sorry but I'm still not convinced swapping out the block is the only way to achieve success. Still hoping there is someone out there who has the answers I am looking for. Thank you all for your input.
