idling problem
Old Jun 17, 2005 | 11:32 AM
mikemerc85's Avatar
mikemerc85
Git-R-Done
Default idling problem
im so pissed right now . I hadda change a coolant hose cause it was leaking. now the book says when u change the refill the rad fluid u have to have the engine running to keep air from gettin into the block. Well while i was filling up i was waiting for the thermostat to kick in and i was gettin impatient. So i stepped on the gas pedal and held it for a couple seconds and it start idling weird. Now it didnt do this b4 i touched the gas pedal. DO u guys think that could of caused it to idle weird and what can i do to fix this prob. thanx.
Old Jun 17, 2005 | 02:57 PM
mtbprelude's Avatar
mtbprelude
RIGHT Wheel Drive!!!!
You have air in the coolant lines....with the radiator uncapped, let the car idle until the fan kicks on or the coolant just begins to 'burble' out the radiator cap. If that doesn't work, you have a vaccuum leak somewhere as well.
Otherwise, do a search for all other idle related posts.
Old Jun 17, 2005 | 07:51 PM
diamondsleeper's Avatar
diamondsleeper
1990 & 1991 Si 2.05
Isnt there a bleed port for the coolant where your coolant senors are in the tach area?
Old Jun 18, 2005 | 06:33 AM
2legit2quit's Avatar
2legit2quit
You Big Dummy
Yes there is, it's on top of the thermostat housing. It looks like copper. If you open it up, whatever you do, DO NOT ovetighten it. Overtightening will break the thermostat housing.
Old Jun 18, 2005 | 11:26 AM
mikemerc85's Avatar
mikemerc85
Git-R-Done
yeah i bled it this morning and there was alot of air. I was so much in a hurry yesterday to get it done that i forgot to bleed it.
Old Jun 18, 2005 | 08:19 PM
diamondsleeper
1990 & 1991 Si 2.05
So did this solve the problem?
Old Jun 19, 2005 | 03:09 PM
mikemerc85's Avatar
mikemerc85
Git-R-Done
yes it did, runs fine now.
