HELP! Key stuck in the ignition
Old Jun 14, 2005 | 03:27 PM
MaNho's Avatar
MaNho
Default HELP! Key stuck in the ignition
Help, my keys is stuck in my 1999 prelude, is there a way to take it out???
Old Jun 14, 2005 | 04:30 PM
VPUPPY's Avatar
VPUPPY
is this an automatic car? is the key all the way turned to the off position?
Old Jun 14, 2005 | 04:45 PM
MaNho's Avatar
MaNho
It's an automatic. The keys turns to off position but does not go the extra notch where you can take it out.
Old Jun 14, 2005 | 04:48 PM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
Ok let's think about this. Normally it wont come out if you _____________.
And you said it wont go the extra notch...
Maybe you go could ahead and lock the wheel, then unlock it and see what happens after that.
Old Jun 14, 2005 | 04:54 PM
Mkazm83's Avatar
Mkazm83
Snapping bolts
Maybe you could ahead and lock the wheel then unlock it and see what happens after that.
HAHAH :rofl:
Old Jun 16, 2005 | 06:47 PM
fastball's Avatar
fastball
A little chin music
From: Cleveland, Ohio - Rock 'n Roll capitol of the World
Go here:
https://www.honda-acura.net/forums/s...+switch+recall
Old Jun 17, 2005 | 04:37 PM
stereo's Avatar
stereo
try disconnecting the battery (make shure you have radio code handy if stock radio) with the battery disconnected the key may come out if the solenoid is engaged. also does the P on your dash come on when is park ? if not then theres somthing wrong with the shift position switch and your car doesn't know it's in park and not letting you take the key out.
Old Jun 18, 2005 | 10:01 AM
VPUPPY's Avatar
VPUPPY
werd. this most likely your problem.
Old Jun 18, 2005 | 11:24 AM
VTEC-Power's Avatar
VTEC-Power
This might sound stupid but it happens, make sure it is in park, also if it is put it in reverse then park again, sometimes it jams
Old Jun 18, 2005 | 08:20 PM
diamondsleeper's Avatar
diamondsleeper
1990 & 1991 Si 2.05
Take it apart and throw it on the cement a couple of times
