JDM Foglight Problem!!!!
Ive had jdm fogs in my 5th gen lude for about 3 months now.....they stopped working a month or so after i put em in and i found out the fuse was blown.....they stopped workin a couple days ago and i figured it was jus the fuse again...but it wasnt...i took out the fogs and hooked em up to the battery and they both light up...any ideas?? i checked all the connections behind the fogs and the connections under the dash....they all look good....any ideas???? it really frustrates me when stuff doesnt work, especially stuff like this
:werd: Since you installed them yourself, it shouldn't be to hard to just trace over the wires. Maybe one of them got pinched somewhere along the line.
I'm with you, I hate when stuff stops working, you get all worked up and it ends up being something really obvious.
ya i replaced the fuse with a 15 jus like it was b4....ya i checked the relay...still clicks...i traced over the wires i ran once and they seem fine....u think it can be some wiring that was factory and i didnt run?? im gonna whip out a multimeter tom...reallly frustrating
ok...my fog lights went out again...it was the fuse....replace the 15 mini fuse and right when i put the fogs on, the fuse fried right away....i replace it once more and fuse fried right away.....i did the h3c to h3 conversion and put silverstars in em if that means anythin.....shud i put in like a 20 amp mini fuse??
