check engine light reset
Old Jan 24, 2005 | 03:49 PM
GpoppLude's Avatar
GpoppLude
Default check engine light reset
ok, i put my cia on the other day and when i did the check engine light came on and is still on but everything looks fine, where can i find the button to reset the light?
Old Jan 26, 2005 | 03:01 PM
yankee81116's Avatar
yankee81116
there is no button...u need to get urself one of those obd2 readers...they have an option that resets the light...the run about 150....another option might be disconnecting ur battery for a bit...that might reset it
Old Jan 26, 2005 | 03:10 PM
teg92's Avatar
teg92
WHAT OK YEAH!
what code is it?
Old Jan 26, 2005 | 05:25 PM
jojolala's Avatar
jojolala
Default reset
the cheapest way to reset is to disconnect your battery for a minute and put it back on. is this what you are looking for?
Old Jan 27, 2005 | 03:11 PM
OD4g's Avatar
OD4g
Like this?
http://www.92lude.com/ecu_reset_procedure.htm
If you havnt already, try this and see what code/s you get:
http://www.92lude.com/diagnose_error_codes.htm
Old Feb 16, 2005 | 08:32 PM
prelude97's Avatar
prelude97
the easiest way to reset it is to pull the [backup] fuse for 10 sec.
