Will jdm p13 work with a usdm h22?
Old Jan 21, 2005 | 11:33 AM
atlaccordguy's Avatar
atlaccordguy
Blah h22a Blah
Default Will jdm p13 work with a usdm h22?
If so will it get the jdm 200 horses. I know the usdm is 190. It is also a obd1 p13 I have a 98 prelude. Will it still work even thought my car is a obd11
Ken
Old Jan 21, 2005 | 02:57 PM
ludeboom's Avatar
ludeboom
uh u wont nec get 200HP from the JDM ecu, the jdm h22 has 10.6-1 CR while all USDM h22a1/4 have 10.0-1
although with an adapter harness you can run the p13 on your h22a4, you may also need to use the OBD1 P13 P+H injector system to run correctly not sure on that one
but to answer your original question...Yes the JDM p13 will work fine with an OBD1 H22a1 USDM motor.
~kris
Old Jan 22, 2005 | 03:40 AM
atlaccordguy
Blah h22a Blah
Thankks boom. There is nothing wrong with the engine now or ecu irt was more for informational puposes.
Kne
Old Jan 26, 2005 | 10:49 PM
sleepersol's Avatar
sleepersol
If it is JDM you will also have a governor at 118 MPH unless you chip it or put on a rev/speed meter.
