i got a question about how to make my top speed higher
Old Jan 19, 2005 | 07:46 AM
5dimes's Avatar
5dimes
Default i got a question about how to make my top speed higher
i got my motor build up pistons,rods,the head,the ecu,i got a question about how to make my top speed higher
Old Jan 19, 2005 | 09:31 AM
monkey's Avatar
monkey
#212
top speed. hmm.
well, more horsepower and longer gears.
longer gears with custom gearbox, or bigger tires. what do you need higher top speed for?
Old Jan 19, 2005 | 10:35 AM
98preludeSH's Avatar
98preludeSH
My Lude already did 146 and thats fast enough for me but if you must go faster the only way is to change your gear ratios which is no easy feat and Im not even sure what gears you could get to put it, again you also need the power to push it to these speeds. Its more trouble than its worth when you can already go to damn fast.
Old Jan 19, 2005 | 11:21 AM
93ACCLUDE's Avatar
93ACCLUDE
NOS
Old Jan 19, 2005 | 12:23 PM
monkey's Avatar
monkey
#212
Originally Posted by 93ACCLUDE
NOS
hmm, if top speed was "hp-limited" NOS would help, but since i think top speed is "gear limited", spraying when you're at 7400 rpm in 5th gear isn't gonna do much for you except blow your engine up.
yeah, like 98 said, your only choices are to get a new set of custom gears, or the easy way is to run bigger diameter tires, which of course kills your acceleration, and throws off your speedo.
anyway, i don't see the point in driving 150 mph, esp when it takes this car about 3 minutes to get there.
Old Jan 19, 2005 | 01:46 PM
jc836's Avatar
jc836
It is gear limited and YES for a large wad of cash you can have custom final drive gearsets made. The downside is that you will sacrifice driveability on the street. If you have a pure track (drag for example) car then that is not an issue. For road racing ther are some other things to consider. ANother thing-Preludes are as aerodynamic as Honda wants them to be-so that will also be a limitation. HP and Torque get the car moving-wind resists beyond a point in the aero envelope.
Old Jan 19, 2005 | 02:44 PM
beier's Avatar
beier
A Philanthropical Fruit
How dose one aquire this knowledge?
Old Jan 19, 2005 | 05:13 PM
OD4g's Avatar
OD4g
Just cruisin around the neighborhood
Old Jan 19, 2005 | 05:15 PM
beier's Avatar
beier
oh ok, I'll try that some time
Old Jan 20, 2005 | 12:12 PM
oscarhmoyano's Avatar
oscarhmoyano
i hited 130 on mine .. honestly .. if it was on a ferrari i would push to 170/180 .. 200, hummm few cars reach that sweet numer tough (super cars), at 200mph .. NOTHING can go wrong.
Otherwise just pray LOL
Oscar
