Weird Engine Noise ... Video Inside.
Old Dec 25, 2004 | 01:12 PM
jtown's Avatar
jtown
Default Weird Engine Noise ... Video Inside.
I've been getting this weird rattling in my engine bay every since I switched back to the stock header. I'm not sure if that's what is causing it, but it happens around 3-4k. I have a video clip for you all ... hopefully you guys can help me out. Thanks!
Right Click Save As ...
Old Dec 25, 2004 | 03:54 PM
Redcivic's Avatar
Redcivic
One of the original OG's
Sound to me like valvetrain is lose. I don't see what changing a header has to do with that sound. Are you sure everything is tight outside the engine?
Old Dec 25, 2004 | 04:44 PM
OUT2WIN's Avatar
OUT2WIN
problem with the valves
Old Dec 27, 2004 | 05:10 AM
Bones45's Avatar
Bones45
Sorry to tell you, but its the dreaded autotensioner. Every 5th gen has this problem. Welcome to the club.
100% guaranteed. How do I know? I just dropped a boatload of cash to have MINE fixed. It make the exact same noise. at around 1600rpm to 1000 rpm. Above that it is fine and at idle it is fine.
The autotensioner isnt doing its job (IT BE BROKE!) and what you hear is the timing belt rubbing up against the timing belt cover.
Its about $600 with parts and labor through the dealer.
Good Luck.
(Im not sure where you get the "3-4000k" rpm range.)
Old Dec 27, 2004 | 02:35 PM
ludeboom's Avatar
ludeboom
yea im with bones on this one that is definitely not a metallic sound, definitely the T-Belt flappin.
~kris
