Idling problem
Old Dec 11, 2004 | 06:06 PM
commeta's Avatar
commeta
Default Idling problem
Hi am having this problem with my Honday Prelude 92si i was wondering if anyone have the same problem and are able to fix it. The problem is that the car does not idle correctly the RPM keeps on moving up and down thanks.
Old Dec 11, 2004 | 07:37 PM
blueboi69's Avatar
blueboi69
you have to replace your throttle body i had the same problem on cold nights, morning, had very high idle. So a certified honda mechanic said replace the throttle body.
Old Dec 12, 2004 | 04:32 AM
teg92's Avatar
teg92
WHAT OK YEAH!
before you replace the throttle body check for vacuum leacks, try cleaning your IACV that might work
Old Dec 12, 2004 | 07:42 AM
commeta's Avatar
commeta
Thanks guy I think am gonna check the vacuum if that's not the case then i'll replace the throttle.
