90 Prelude Radiator-Help
Old Oct 8, 2004 | 07:06 AM
Preluder's Avatar
Preluder
Default 90 Prelude Radiator-Help
I need some instructions on the removal and re-install of a radiator for my 90 Prelude Si. The neck of the radiator where the top hose connects is rusted out and I can't connect a hose to flush either!
Old Oct 8, 2004 | 04:44 PM
Kaspin's Avatar
Kaspin
1991 Prelude Si 4WS
Check in the online manual ( http://www.honda.co.uk/owner/PreludeManual/index.html )
Instructions will be in there
Old Oct 8, 2004 | 05:40 PM
bigt61's Avatar
bigt61
just look for the brackets on either side, top and bottom of the radiator... remove them, walla... u got it out. pretty straight forward common sense.
Old Oct 13, 2004 | 02:10 AM
Preluder's Avatar
Preluder
Default Advice
Obviously, you have never actually done this. There isn't a "straight forward" way to accomplish it either. There is MUCH more to it than removing a few bolts...like maybe hoses, electrical, fan shrouds, getting around coolant lines...not to mention the plastic cover that goes all the way up into the wheel wells on both sides of the car. If it was that easy, it wouldn't have required a question, so don't give advice if you don't have any.
Old Oct 13, 2004 | 02:11 AM
Preluder's Avatar
Preluder
Thanks for the link, but there was only a schematic.
