need some help
Old Sep 26, 2004 | 09:46 AM
TheFedman2002's Avatar
TheFedman2002
Default need some help
hey everyone im new here and i got a problem with my 97 type s prelude. I was drivin yesterday on the freeway and hit vtec in 4th and it seemed normal until i shifted to fifth at about 6000 rpm's and my check engine light went on. I kept driving like normal and took the next exit to my house but when i stopped at the light the idle was low, WAY low, like needle on zero rpm's low. When i started drivin i let out the clutch like usual and it was extremely sluggish until about 3000 rpm's where it picked up a lot and felt like normal. I stopped at a few more lights and the same thing happened. This morning i go out and check the codes and it gave me code 3 which is the MAP sensor. If anyone has some info that can help me out then please tell me. thanks.
Old Sep 27, 2004 | 12:34 AM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
try unhooking the batt and reseting the ECU
might make the cel go off again
Old Sep 27, 2004 | 08:40 AM
Lenn's Avatar
Lenn
dont reset the ECU until you pull the trouble code...
http://www.hondaprelude.to/articles/...ck_engine.html
THEN reset the ECU to see if the code comes back... dont just reset it without finding out why it turned on to begin with....
Old Sep 27, 2004 | 04:02 PM
TheFedman2002
yeah i got the trouble code and when i went out in the morning disconnected the battery, reconnected it, and it started fine. i've been driving it for a day now and no problems, however i havent pushed it into vtec yet, but i still dont know why it idled so damn low
