JDM Prelude type S piston in H23??
Old May 9, 2004 | 04:28 PM
importsyn's Avatar
importsyn
Default JDM Prelude type S piston in H23??
Hey has anyone had any luck using either USDM H22a pistons or even JDM H22 pistons in an H23.I've looked at aftermarket pistons but they recommend sleeving the block on H series motors and they're hard to find for H23.
Old May 9, 2004 | 08:22 PM
monkey's Avatar
monkey
#212
i think the wrist pin would need to be modified to fit the rods and there might be clearance issues? is this for a turbo or na build?
it's possible, but i'm not sure it's the smartest option.
Old May 10, 2004 | 04:28 AM
importsyn's Avatar
importsyn
I just wanted to go N/A.That's why I thought it would be a fairly economical solution.My other concern ,other than clearance issues, is what is the compression ratio going to go to with the H23 head?
Old May 10, 2004 | 07:16 AM
monkey's Avatar
monkey
#212
hmm, without changing the rods it should be somewhere in the 10's i believe.
Old May 10, 2004 | 09:47 AM
Rezza's Avatar
Rezza
Tell your mom I said hi!
with what you'd spend trying to build up your h23, why dont u just swap a h22 longblock in there??? H series VTEC is music to the ears
Old May 11, 2004 | 02:53 AM
drift's Avatar
drift
Flaccid Member
wont fit. the combustion chamber roof on the H23 head is much shallower than the H22 combined with the 1mm of extra length on the H23's rods at TDC will create interference problems that cannot be overcome without a deck spacer... thus defeating your intended goal of upping compression.
Old May 22, 2004 | 04:58 AM
importsyn's Avatar
importsyn
Thanks,I'm going to look into more aftermarket piston options.As fars as going VTEC,I want to see what I can do with this motor.I have a spare H23 in my garage that I'm porting myself so downtime isn't an issue.I've been in a "built" Vtec Prelude and it was awesome but I'm just trying to be different I guess.
Dubs
92+ Civic/EL & Del Sol
17
Dec 31, 2003 10:45 AM
93si4ws
Nov 18, 2003 08:29 AM
ichiro
Jun 15, 2003 10:20 AM
speed614
6
Jan 19, 2003 08:00 AM
Widebody NSX
Nov 7, 2002 07:18 PM
