Eibach Pro-Kit Springs question
Old Apr 30, 2004 | 02:35 PM
Pelka's Avatar
Pelka
::..Prelude..::
Default Eibach Pro-Kit Springs question
Honda just replaced all my struts with OEM Honda struts. Im planning on buying the Eibach Pro-Kit. Would i need an alignment right after i install them or?
Old Apr 30, 2004 | 03:29 PM
5hift's Avatar
5hift
Hades: 2.2L DOHC VTEC
definitely, anytime you modify ur suspension in any way, especially if ur gonna lower it, you're gonna wanna get an alignment, even if you think you don't need it, better to be safe than sorry.
Old May 1, 2004 | 04:18 AM
Pelka's Avatar
Pelka
::..Prelude..::
Thanks man. Honda dealer wants $59.95 for alignment ill just go there.
Old May 1, 2004 | 07:20 AM
elbee's Avatar
elbee
Make sure you ask for a printout beforehand!
Old May 1, 2004 | 05:28 PM
Pelka's Avatar
Pelka
::..Prelude..::
Printout of?
Old May 1, 2004 | 11:24 PM
TheCrazyRussian's Avatar
TheCrazyRussian
'93 Prelude Si stock...
probably what they are going to charge you
Old May 2, 2004 | 12:29 PM
Pelka's Avatar
Pelka
::..Prelude..::
I got a hook up at a Honda dealer... so it will be less than expected...
Old May 3, 2004 | 06:35 AM
ludeboom's Avatar
ludeboom
he means a print out of your alignment before they align it
that way you can see how much you were off and what was adjusted.
there are 3 basic angles, camber/caster/toe
there are also other measurements that you will notice on the printout, but these seem to differ by name, depending on where you get it aligned and what type of alignment computer the place uses.
either way things to consider:
they may not want to align it if its lowered, even 1.2 inch's.
you OEM struts may not last as long with lowering springs, as opposed to stock springs.
you will bottom out a lot more, i have a prokit and i bottom out on every speed bump now
but the handling IS worth it, at least to me since i push my lude to the limit daily.
~kris
Old May 3, 2004 | 02:09 PM
Pelka's Avatar
Pelka
::..Prelude..::
Boom wsup man? Whats the height from pavement to body? With the pro-kit? 6"?
BreaKnBarrierz8
92+ Civic/EL & Del Sol
8
Apr 7, 2004 03:13 PM
Meguel24
13
Jul 11, 2003 11:56 AM
LoVeAllah2
Accord
6
Jul 9, 2003 05:12 PM
nosaccord2k
May 10, 2003 02:05 PM
