97 Prelude hesitation problems
Old Jan 8, 2004 | 05:21 PM
wage's Avatar
wage
Default 97 Prelude hesitation problems
My girlfiend has a 97 and about a year ago it started to have a very sporadic hesitation problem. It's so hit or miss that the we have had honda take it for a ride 4-5 times and it won't do it for them (figures!) I was wondering if there are any known issues with maybe the emissions controls or some other kind of electrical part. My first option was to give it a tune up (although one was done 15k ago) just to eliminate any questions. WE were told by Honda that the computer would pick up a misfiring wire or plug and send a coad so a tune up probably wouldn't do the trick.
The problem...It doesn't happen all the time which makes it hard to pinpoint. I find it the worst after the car has sat for 45 min to an hour and we get back in it. This is a MAJOR hesitation in the LOW RPM range and mostly noticeable in 1-2 gear. I would say it's below 3500 rpms. Any thoughts/suggestions??
Thanks in advance!!
Old Jan 9, 2004 | 11:18 AM
Bones45's Avatar
Bones45
Odd that you mentioned this.
I have found this happening on my '00 5spd. When cruising at top gear at low rpms...(under 3000 rpm), I will feel a split second hestitation. Its hard to explain, but the best way to describe it is if the clutch was pushed in for a split second causing the car to slightly lose its forward momentum...and then regains it.
Its only for a second..and probably not noticeable to a passenger, but the driver will notice. It also doesnt happen all the time. Maybe once a month?
Very odd. I never thought of bringing it to anyone b/c it will most likely never happen for them.
Old Jan 9, 2004 | 11:48 AM
MINI NSX's Avatar
MINI NSX
I wish I knew what the problem is, too. My '99 has a slight hesitation, and when I took it in to get the ignition recall done, they said that they didn't notice it when they took a test drive. I just wish they would have put the thing on a diagnostic machine and checked the engine settings (CO, timing, etc.), but NO, they didn't!
Old Jan 9, 2004 | 03:13 PM
wage's Avatar
wage
Hers has been on the machines and on test drives. It has to happen while on the machine or set a trouble code. It's done niether. Guess it's time to get rid of the Lude.
