5th Gen Clear front blinkers
Old Dec 17, 2003 | 01:09 PM
5hift's Avatar
5hift
Hades: 2.2L DOHC VTEC
Default 5th Gen Clear front blinkers
Is there anyway to install clear front bumper blinkers on a '97 Lude without a lift or taking off the entire front bumper? Any help is appreciated.
Old Dec 17, 2003 | 02:22 PM
97 VTec Lude's Avatar
97 VTec Lude
its easy... if you already have the clear turn signals, just take a screwdriver and go through the middle of the grill, and you should see where the screw is, its on a diagnal facing out towards the grill, unscrew it, and the turn signal should be loose and you could pull it out very easily. Then, unplug the light from the turn signal (turn and pull out), and then grab the clear turn signal, put the light back in the same way you took it out, mount the turn signal back into the bumper, and screw it in.
ill take some pics of where the screw is for you in a few, hope this helps, later man.
Old Dec 17, 2003 | 02:32 PM
97 VTec Lude
this is looking from the middle of the grill space to the left turn signal, and you can see what screw to unscrew. Later man, hope this helps.
Old Dec 17, 2003 | 05:01 PM
5hift's Avatar
5hift
That's helps a ton, I appreciate it man. Thanks a lot.
Old Dec 17, 2003 | 07:55 PM
97 VTec Lude
your welcome.. enjoy the lude
Old Dec 18, 2003 | 04:42 AM
Prelude00Red's Avatar
Prelude00Red
thanks man for the installation tips, i needed them too.
Old Dec 18, 2003 | 09:09 AM
97 VTec Lude
your welcome.. ha, enjoy the lights
