Help Installing Rear Lower Tie Bar
Old Dec 15, 2003 | 07:36 PM
StreetAssassin's Avatar
StreetAssassin
Default Help Installing Rear Lower Tie Bar
I just got a DC REAR LOWER TIE BAR for my 01 Prelude, and i can't figure out exactly where to install it, so if anyone with a 92-01 prelude or 90-97 accord has one, please tell me where exactly you installed it, or better yet, anyone with one, post a close up pic, and i will get it from there. thanks for the help
Old Dec 17, 2003 | 03:39 PM
StreetAssassin
Nobody?
Old Dec 17, 2003 | 09:26 PM
ludeboom's Avatar
ludeboom
yah i have one
there are 2 bolts, one on each side where the lower control arms are bolted to the rear cross beam
the tricky part is that the bolts you want to connect to are not facing down, they are facing the rear of the car, you should be able to see the rear crossbeam from looking under the rear bumper, and you should see a bolt at each end facing at you, its actually a nut, take the nut off and pop the bar on, then retighten, i recommend around 48 ft/lbs
~boom
Old Dec 18, 2003 | 12:40 PM
StreetAssassin
Thanks alot, your info was a great help!
