Front Upper JDM Strut Bar
Old Dec 6, 2003 | 10:25 PM
DSBenjamin's Avatar
DSBenjamin
Default Front Upper JDM Strut Bar
I had just purchased a JDM genuine Honda strut bar for my 2001 and when i went to install it i had a problem....most strut bars screw into the bolts that hold the strut...but this has 2 bolts and they screw into 2 holes (that are covered by plastic things). Well wen i actually got the bolts to screw into the hole, i realized that the plate that holds the strut to the body is covering up part of the hole...so tommorow i am going to take both struts out rim out the plate a little bit and put the strut bar in...The question i have is... since the bar is only going to be screwed into the body, not holding the 2 struts together, will it make a difference?? PM or reply...thanks
Old Dec 8, 2003 | 06:34 PM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
damn all that trouble for a strut bar
should've went with the Neuspeed or skunk2
good luck
Old Dec 8, 2003 | 06:40 PM
DSBenjamin's Avatar
DSBenjamin
Got it in...wasnt too hard didnt have to remove strut, just lower it a little..i could feel the difference and i love how it looks stock
Old Dec 9, 2003 | 02:00 PM
ludeboom's Avatar
ludeboom
PICS
i want one now
Old Dec 12, 2003 | 03:23 PM
vtecguy2's Avatar
vtecguy2
forrreals....PIX PLEASE....!!!!!
Old Dec 12, 2003 | 07:56 PM
THATPRELUDEGUY's Avatar
THATPRELUDEGUY
I suck!
It's a standard OEM piece, black stamped steel and tubiing. As for bolting it ot the car? I've seen them and they install just like any other tie bar, take the two bolts off that hold the strut in and drop the bar on and bolt it back down.
Old Jun 4, 2004 | 09:16 AM
VTIR's Avatar
VTIR
To install it properly u need the strut bar mounts that go onto you suspension
Old Jun 4, 2004 | 09:39 AM
Samson's Avatar
Samson
chris is the devil
werd...
