H22 timing belt question
Old Oct 22, 2003 | 09:34 PM
H22aBean's Avatar
H22aBean
Default H22 timing belt question
Yeah i have a problem with my timing belt it slides off to the outside of the camgears. I have skunk cams and camgears. It really just started after i got the cams.
ive changed the auto tensioner like 3 or 4 times and no avail. Im going to auto-manual tensioner conversion, but i was wondering if anyone else had this problem and how they fixed it. i was thinking the waterpump might be going bad, and that might tension the intake side of the belt or something, not idea
Old Oct 23, 2003 | 05:16 PM
H22aBean's Avatar
H22aBean
lil help
Old Oct 23, 2003 | 06:40 PM
boostlee's Avatar
boostlee
are they the correct cam gears and cams for the car??
how much are they sliding off....alot??
Old Oct 24, 2003 | 10:22 PM
H22aBean's Avatar
H22aBean
yeah they are the correct gears and cams, and its sliding off enough to rub on my balance shaft pulley. It was a lot owrse it rubbed on ths inside of my valve cover to the point it wore away the metal, it wasnt pretty. it just slide off no matter what. And there is more slack on the exhaust cam then the intake cam.
