??? Camber ???
Old Oct 11, 2003 | 05:21 PM
Louie002's Avatar
Louie002
Default ??? Camber ???
I got a question
Is it true that you can
Adjust camber using a upper pillow mount
Or am I going to need a camber kit
Old Oct 13, 2003 | 11:36 AM
jc836's Avatar
jc836
Since you do not tell us what generation your car is I can say that for both 4th and 5th gen Preludes the answer is No. The pillow mount has nothing to do with Camber on these cars. You need kits that affect the upper control arms both front and rear. You can find both Anchor bolt and sliding ball joint kits at www.ingallseng.com or www.specprod.com. These are the 2 primary manufacturers of parts for our cars.
Old Oct 16, 2003 | 12:29 AM
Louie002's Avatar
Louie002
it's for a 5th gen prelude
Type SH to be exact
Old Oct 16, 2003 | 08:40 AM
jc836's Avatar
jc836
Both companies have a solution that will help you. Sadly, the SH is a bit different from other models of 4th and 5th gen-but there is a balljoint kit that should work up front. The rear is identical to both the 4th and 5th gen BASE.
Old Oct 16, 2003 | 08:57 AM
monkey's Avatar
monkey
#212
i really wish we had a skunk2 style camber kit option.
the ingalls kit seems way overpriced.
