FS: Soundstream Reference 414S
Old Aug 24, 2003 | 02:36 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
Default FS: Soundstream Reference 414S
I've had the amp for about 8 months. No problems with it at all, im just slowly trying to get the amps that I want(Lanzar OPTIdrive series) so the Soundstream has to go. My goal is to build an amp rack displaying the amps and I think having the same model amps looks so much cleaner. Here are the specs:
50x4 @ 4ohms stereo 12volts
75x4 @ 2ohms stereo 12volts
100x4 @ 1ohm stereo 12 volts
THD less than 0.1%
Signal-to-Noise >100 dB
Frequency Response 20 Hz to 20 kHz
Stereo Separation >90 dB
Damping >200
Input Sensitivity (Ref414s): 200mV - 5.OV (Ref414s)
Input Impedance 10K ohms
Crossover Output 340 mV output w/200 mV input (+4.5 dB)
Crossover Specifications(variable crossovers)
Low Pass: 30 - 120 Hz at 24 dB/octave
High Pass: 60 - 240 Hz at 12 dBloctave
Dimensions (Ref414s): 15.25” W x 2.25” H x 9.8”D
Here's a pic, not the acutal amp I have for sale, but you get the idea.
My amp is in excellent condition, I had "SoundStream" polished, as well as the thick bar running across the top. I'm asking $175 obo for it.
Old Aug 25, 2003 | 07:46 AM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
ttt
