Tein CST Coilover Suspension for 2004-2008 Acura RL
Tein Comfort Sport Coilover for 2004-2008 Acura RL. Had it on the car almost 3 years and put about 22XXX miles on it. Still in excellent condition. Brand new goes for $2020 brought it from www.optionautosalon.com. Cheapest I've seen goes for $1917. Item are special order from Japan. Compatible with EDFC (not included). Sell for $1100 Pick Up or $1150 SHIPPED.
Contact me at hobbyemporia168(at)hotmail(dot)com for more info.
Current Spec:
Spring Rate F:8kgf/mm Part# SC080-01250
Spring Rate R: 9kgf/mm Part # S6B23-01090
Spring Rate Adjustable Range F: +2.0~-2.0,
Ride Height:-1.2,Ride Height Rear:-0.7
Height Adjust Range (F):-0.8~-2
Height Adjust Range (R):0.6~-1
EDFC Available:EDK05-12120
Special order from Japan
The Comfort Sport Damper has been specifically designed for drivers seeking to improve performance, without sacrificing ride quality. Vehicle sway is reduced to increase stability during cornering and increase handling. This coilover kit features a special fluorocarbon coating to protect against corrosion. The mono tube internal design with new MSV technology allows for smooth and quiet operation. Ride height and damping force adjustable (16-levels), as well as EDFC compatible. Developed with larger wheels and tires in mind, the spring rates and damping force provides the perfect balance of performance and comfort.
Additional Features:
• Steel Construction
• Mono Tube internal construction
• 16 way adjustable dampers, compression and rebound combined
• M.S.V. Technology for improved comfort
• Ride Height adjustable via spring seat
• Hardened Rubber upper mounts with silencer ring for increased steering feel
• Inverted design for strut type front and rear
• Teflon coated shock body
• EDFC Compatible
Contents of Damper Kit:
Adjustable Shock Absorber × 4 Bump Rubber × 4
Main Spring × 4 Hook Spanner × 2
Upper mount × 4 Dust Cover × 4
Some applications include helper springs Instruction Manual × 1
Seat Lock × 12 Sticker Sheet × 1
Current Spec:
• EDFC Compatible
