FS: 1996 EJ8 (Civic EX Sedan)
Old May 19, 2003 | 11:27 AM
bew's Avatar
bew
Default FS: 1996 EJ8 (Civic EX Sedan)
EDIT: Forgot to mention, the title is CLEAN!
This car is a 5spd 1996 Civic Sedan, EX model. It had 120k miles on cluster before I removed it. It is a rolling chassis right now, meaning it has no engine, tranny or ECU. It still has the wiring harness though. I pulled the D16Y8 a couple months ago and sold it with other plans in mind, which fell through. I thought about putting an H23/Vtec in this car since I have most of the parts already, but I want to get an Integra still so I might sell this car.
It has all of the interior parts also, some are painted white (stupid previous owner was a ricer).. but they can be stripped and returned stock easily. It also needs a gauge cluster to finish off the interior. It also has a cheap Tsudo exhaust, clear tail-lights and stock tail-lights. And a cheapo KOSS cdplayer.
The exterior needs a little work since its not perfect. It needs the following:
Drivers side Fender
Drivers side door (if you cant do bodywork, teh damage is not bad if you can)
Passenger door (same as above, its perfect cept where somone tried to break into the door handle with a screwdriver)
Both bumpers are cracked, but good otherwise.
I'm just looking for offers right now. I will more than likely return it to stock and sell it for alot more..but IF I can get enough for it how it sits.. then I will sell it.
As you will see from the pictures below, it's not TOO bad.. just needs some TLC. In those pics, you might notice the door didnt close all of the way, I have already fixed that problem so that's no longer an issue. It's been tested for leaks too and has no problem with water.
Here is pictures of the car how I got it, and it will look the same when you get it:
VIN Number will be supplied to those interested..
This pulled from Edmunds.com 's TMV (True Market Value) Pricing Guide.
Keep in mind, these prices would be valid if the car were repaired and returned to stock! I'm just adding this info to show comparisons on value incase somone was interested in buying this car to make some money on it. I'm not even looking to get HALF of the Dealer-Trade in Value how it sits, which is fine.
1996 Honda Civic
4 Dr EX Sedan
Dealer Trade-In Private Party Dealer Retail
Regional Base Price for
Zip Code 37217
$4,992 $6,154 $7,760
Again, this was pulled from Kelly Blue Book, given the vehical be in good condition (repaired and returned to stock):
1996 Honda Civic EX Sedan 4D
Engine: 4-Cyl. 1.6L VTEC
Trans: 5 Speed Manual
Drive: Front Wheel Drive
Mileage: 123,000
Equipment
Air Conditioning
Power Steering
Power Windows
Power Door Locks
Tilt Wheel
Cruise Control
AM/FM Stereo
Single Compact Disc
Dual Front Air Bags
ABS (4-Wheel)
Moon Roof
Private Party Value $4,955
Private Party value represents what you might expect to pay for a used car when purchasing from a private party. It may also represent the value you might expect to receive when selling your own used car to another private party.
As said before, I am just looking for offers. If an offer is made that we both consider fair, then the car will be sold.
bewsi@comcast.net
bewSi - AIm
