lsvtec del sol
Old Feb 21, 2003 | 11:54 AM
lsvtecsol's Avatar
lsvtecsol
Default lsvtec del sol
Hi. I have a white 1995 white del sol s with ls/vtec swap.
The motor consist of b18a block with pr3 piston, type R pistons rings, new rod and main bearings, vtec oil pump, arp rod bolts, and seals. The head is a jdm b16 II head with dual gs-r valve spring and retainers, type R intake cam, b16 exhaust cam, skunk 2 im, msd 6al ignition, cam gears, dc type R 4-1 header, pyr p28 ecu, v-afc. The trans is a jdm y21 with act hd pp and ss disc mounted to a jun flywheel (only 2000 miles on clutch/flywheel) and 12,000 miles on motor. The car dyno tune at 174 whp and 123 lbs of torque. With wilder cam, the car will put old more hp and torque. The rims are 99 si rims with kuhmo tires on it. Suspension consist of tokico adj on front with skunk 2 coilover all around. I'm asking $6000 for the car and will have pix this sunday. Reason i'm selling is to pay off the engagement ring for my g/f.
I also have a 91 eagle talon tsi with rebuilt motor with all new parts and bore .20 over. The motor only has 1000 miles on it and come with momo steering wheel, manuel boost controller, act clutch, greddy turbo timer. The turbo is new as well and replace when motor was rebuilt. I'm asking $2500 for this car. I need to sell either one or the other to pay off the ring. Email lsvtecracer@yahoo.com if anyone is interested. Thanks.
