FS: QuadShift Racing Sequential Shift Light
Old Jan 18, 2003 | 09:21 PM
djsmith's Avatar
djsmith
Default FS: QuadShift Racing Sequential Shift Light
QuadShift by DKS Electronics
Outstanding Features and Functionality for the RACE version:
Just like the ones used in Touring car racing and road racing.
Super Bright Lights:
First orange is 1600 mcd, second and third yellow 1440 mcd and the final Red light is 6800 mcd. This is many times brighter than any other shift light on the market. Very wide range from 1000 to 12,000 rpm (4 cyl) No extra 'pils' or switches to buy, works on all 4, 6 and 8 cylinder engines. Adjustable from idle to maximum via control module.
Individually program all 4 Lights:
With most other shift lights in the market, you can only set the final light and the others just come on at a preset RPM. Why is our product better? You can program each light to a different RPM. So you can make it a 4 light sequential shift light or so that the first light to be an indicator of the bottom of your torque band. Also the first light can be set as a shift up or shift down, that is if you drop below your torque band have the light come on or have the light come on while you are in the torque band.
Size Matters:
One of the smallest sequential shift light on the market, display is only 2" x 0.75". Easy three wire installation
Features:
Small display box
Bright lights
Reprogrammable
Dimmer on/off switch
Each light can be set to a different RPM
All lights can be set to the same RPM
First light can be set to come on or off at the set RPM
Easy installation
Works on all engines 1-8 cylinder including rotories
www.quadshift.com
