FS: Fully tucked engine harnesses!
FULLY TUCKED ENGINE HARNESSES!!!!!
Okay guys, my good friend Chase, aka CHASE BAYS (cali) is giving me a good deal on all these harnesses!! they're badass and fully tucked! For mostly every Honda/Nissan Motors! Perfect for show cars and engine bays that you want to clean up!!! These engine harnesses are extremely slick and professional! If you have any questions email him at ChaseBaysOnline@gmail.com.
****3 Harnesses out right now to suit all applications. From the more Budget engine bays to the Bossiest of engine bays! Almost everything is in stock and ready to ship!! Please take the time to read each description before asking questions. All harnesses are available for any K, B, H, F, and D series motors. S2000's included. Email for any orders.
CM1 Harness: Re-done stock harness re-made to fit more stealthy/tucked and loomed in nylon sleeving and heatshrink. (for B,D,H.F both sides of the shock tower clips are joined to one; designed to enter the center of the firewall for the stealthiest look)
- $450 shipped w/ a core engine harness.
- $570 shipped w/ no core.
CM2 Harness: Re-used wire and plugs but completely "reshaped" the best way possible, with a Mil Spec quick disconnect connector for the firewall. Loomed in nylon sleeving & heat shrink or full heat shrink. Default connector location is on the old A/C oval hole on the far left of the engine bay. Aluminum plate included to rivet into the firewall & hold the connector. Connector location on firewall available anywhere if needed. ALL CM2 harnesses go straight to the ECU clips for all chassis. Thus deleting the need for a OBD jumper harness in most chassis'.
- $760 shipped w/ a core engine harness.
- $890 shipped w/ no core.
CM Milspec: Full Mil Spec engine harness. All brand new: Harness pins, Mil Spec wire, Raychem DR-25 heatshrink, adhesive shrinked junctions, yellow sensor labeling, Mil Spec quick disconnect for the firewall. THE BEST harness money can buy. ALL CM2 harnesses go straight to the ECU clips for all chassis. Thus deleting the need for a OBD jumper harness in most chassis'.
- $1520 shipped w/ a core engine harness.
- $1560 shipped w/ a no core.
CM1 Harness:
K series:
B series:
CM2 harness:
CM Mil Spec:
ALSO, WHEN YOU EMAIL HIM, MENTION "AUDZ" REFERRED YOU AND YOU GET 10% OFF!!!! SUCH A DEAL!! W00T!!
HAPPY HOLIDAYS!!
CM1 Harness:
K series:
B series:
CM2 harness:
CM Mil Spec:
HAPPY HOLIDAYS!!
