FS: Some gsr maintainance parts
Well guys I just did some routine maintainance and have some stuff you guys might want to use for a temporary fix/repair.
All items were removed from my 01 GSR with just over 87k miles. All items work/good condition (thermostat, water pump, belt). No items were removed due to being faulty, just decided to replace everything given the mileage. Upon removal, things looks surprisingly good. Replaced thermostat because I drained/filled the car with new coolant so replaced it while I had it all drained out, works perfect.
-oem timing belt seems in good condition, no tears or signs of breakage
-oem water pump blades move freely, might need a new gasket and some cleaning which is easy
-oem side mount bolts/washers
-oem timing belt tensioner/spring seems in good condition and also the spring is included
-oem thermostat looks clean and worked when i removed it
-oem valve cover some paint is flaking but can easily be repainted, never leaked.
Make an offer on everything, i'm letting this stuff go REAL CHEAP. I accept PAYPAL only or if you're local you can just pick up what you want (northern NJ).
Here are some pics:
Here are some pics:
