95 GSR part out. 5 lug, built motor, LSD, turbo kit, JDM front end, Recaros, rolling
I am parting out a 95 integra gsr. It was a project car I bought from a friend that I don't want ot put back together.
type R 5 lug gunmetal wheels $600
type R 5 lug conversion (brakes and suspension) $800
JDM Recaro type R seats $900
Built gsr motor $2000
gsr trans with type R LSD installed $900
ECU $150
engine harness $150
stage 3 6 puck clutch $100
lightened oem flywheel $65
blox intake manifold $95
stock fuel rail $15
stock injectors $25
gsr throttle body $40
new axles $90
stock radiator and fan 30
triple gauge pod $10
obx amp gauge $10
type R wing $55
Ross 81.5mm pistons w/ rings (new) $200
81.5MM headgasket (new) $50
I would like to sell the shell as a rolling chassis, but I will part out if no one wants it. Its type R yellow, with a JDM front end (black housing nonHID headlights). Motorcycle gas lid and MR2 taillights molded in. Shaved moldings and antenna. Almost complete wire tuck. black interior. Cat-back exhaust, dropzone shocks and coilovers. GSR wheels with drag radials up front. $2000 with JDM front end. $750 without.
Also have a complete turbo kit, including: t3t4 turbo, manifold, 35mm wastegate, BOV, all intercooler piping, front mount intercooler, oil lines, and 3" downpipe. $800
Will sell the motor, trans ecu and harness for $3000
Wheels:
http://i76.photobucket.com/albums/j1...8/IMG_3205.jpg
http://i76.photobucket.com/albums/j1...8/IMG_3206.jpg
5 lug:
http://i76.photobucket.com/albums/j1...8/IMG_3209.jpg
http://i76.photobucket.com/albums/j1...8/IMG_3210.jpg
http://i76.photobucket.com/albums/j1...8/IMG_3211.jpg
http://i76.photobucket.com/albums/j1...8/IMG_3212.jpg
clutch:
http://i76.photobucket.com/albums/j1...8/IMG_3218.jpg
http://i76.photobucket.com/albums/j1...8/IMG_3217.jpg
flywheel:
http://i76.photobucket.com/albums/j1...8/IMG_3219.jpg
http://i76.photobucket.com/albums/j1...8/IMG_3220.jpg
trans:
http://i76.photobucket.com/albums/j1...8/IMG_3213.jpg
http://i76.photobucket.com/albums/j1...8/IMG_3215.jpg
motor:
http://i76.photobucket.com/albums/j1...8/IMG_3223.jpg
http://i76.photobucket.com/albums/j1...8/IMG_3222.jpg
http://i76.photobucket.com/albums/j1...8/IMG_3224.jpg
http://i76.photobucket.com/albums/j1...8/IMG_3225.jpg
manifold, injectors, fuel rail, throttle body, radiator gauge pod:
http://i76.photobucket.com/albums/j1...8/IMG_3226.jpg
http://i76.photobucket.com/albums/j1...8/IMG_3230.jpg
http://i76.photobucket.com/albums/j1...8/IMG_3228.jpg
http://i76.photobucket.com/albums/j1...8/IMG_3229.jpg
http://i76.photobucket.com/albums/j1...8/IMG_3221.jpg
http://i76.photobucket.com/albums/j1...8/IMG_3227.jpg
ECU $150
engine harness $150
stock fuel rail $15
stock injectors $25
new axles $90
obx amp gauge $10
type R wing $55
Wheels:
5 lug:
clutch:
flywheel:
trans:
motor:
Shell:
http://i76.photobucket.com/albums/j1...8/IMG_3231.jpg
http://i76.photobucket.com/albums/j1...8/IMG_3232.jpg
http://i76.photobucket.com/albums/j1...8/IMG_3234.jpg
http://i76.photobucket.com/albums/j1...8/IMG_3233.jpg
http://i76.photobucket.com/albums/j1...8/IMG_3236.jpg
http://i76.photobucket.com/albums/j1...8/IMG_3238.jpg
Recaro seats:
http://i76.photobucket.com/albums/j1...8/IMG_3235.jpg
http://i76.photobucket.com/albums/j1...8/IMG_3237.jpg
Turbo kit:
http://i76.photobucket.com/albums/j1...8/IMG_3243.jpg
http://i76.photobucket.com/albums/j1...8/IMG_3244.jpg
http://i76.photobucket.com/albums/j1...8/IMG_3245.jpg
http://i76.photobucket.com/albums/j1...8/IMG_3246.jpg
http://i76.photobucket.com/albums/j1...8/IMG_3247.jpg
Recaro seats:
Turbo kit:
This used to be my friends car. He installed the turbo on the stock motor and blew the ring lands on the second cylinder. Then we pulled the motor and built the bottom end, 82mm je pistons, eagle rods, new bearings and rings, arp rod bolts and head studs, ported head... While the motor was being put together he bought the 5 lug and the wheels, but never put them on. He ran out of money so I bought everything from him and I don't want to put it back together so I'm parting it out.
If someone wants to buy everything and put it back together it will be a pretty amazing car. I don't have enough time to do it myself.
ross 81.5MM pistons 8.5:1 compression
http://i76.photobucket.com/albums/j1...8/IMG_3239.jpg
81.5mm headgasket
http://i76.photobucket.com/albums/j1...8/IMG_3242.jpg
These are brand new, decided to go with the 82MM JE's before installing these.
81.5mm headgasket
