Complete LsVtec setup for sale
Hi, I've got the following parts for sale, will only sell the bottom end and the top end seperate. Best offer takes it
Bottom end
cleaned B18A block and crank
new P73 (Integra Type R) Pistons w/wrist pins
new Z10 Engineering crank girdle
new ITR oil pickup and windage tray
PR4 rods w/ polished beams
new vtec oil pump, water pump and timing belt
new oem crank and rod bearings
ARP Rod bolts
new main bolts
new piston rings
OEM pully and flywheel
complete oem bottom end gasket set for b18a
top end
B16A cylinder head w/ >60,000 KM
B16A Intake and Exhaust Cam
Black Valve cover B16A Intake Manifold complete w/ sensors, rail, injectors and tb
B18A Exhaust Manifold
PR3 Distributor
New OEM Vtec head bolts
new oem gasket set for top end (minus head gasket and valve stem seals)
+I'm sure there are other parts I've forgotten. All you'd need to make an LsVtec is the head gasket,
the external oil lines, and most of the machine work done.
Aswell I have a chip burning kit which allows you to burn your own ecu's. Everything is included in the kit to chip your ecu, then you can chip other people's and sell it to them. Its like Hondata, except you can do it over and over again, email me if intrested, I'll sell that to the top bidder aswell.
If there is anything else you are looking for, let me know, and I'll see what I can dig up.
Bottom end
ARP Rod bolts
new main bolts
new piston rings
top end
PR3 Distributor
Well, I have an offer of $1000 on the bottom end right now, and the guy is comming tonight to have a look at it, and I figure the head is worth $500, so $1500 for the whole thing, or $500 for just the head, e-mail me and let me know what you think:
kanga_rod@hotmail.com
