FS: ANR Hondata S300 ITR Head ITR 4.785 LSD Tranny and Much More B series galore!
The Motor is in the car and everything will be pulled out in about a week. I no longer deal with Paypal. Everything will either need to be picked up with cash. or Certified Check or Postal Money Order.
Car is going back to stock and im buying a K swapped car.
1. 98 Spec Integra Type R Head. Port and Polish from Honda. Best cams that came out of the B series from Honda. Complete with Brand new Distributor, BLox Intake Manifold with Hondata intake manifold Gasket. Type R 66mm TB. all sensors are there STR Fuel Rail with Holley FPR. Automete Fuel Pressure Gauge. Stock 240cc Injectors $1500 This is COMPLETE HEAD with intake system
2. B16a2 Block. Comes with ARP headstuds. Rings were installed 22k miles ago. No scars on the sleeves. Fresh Oil Pump, Timing Belt, Water Pump, Oil pan Gasket done 5k ago. $700
3. ANR Equal Length with Merge Collector. 2 o2 bungs one for o2 and the other for your wideband. 2.5" Paid $900 will take $600
4. Hondata S300- Stand Alone in P28 ECU. $800
5. JDM ITR Transmission. Has 24k Miles on it. JDM 4.785 Final Drive. Carbon Synchro's.. NEVER Grinds. OEM LSD Fresh Seals and Input Shaft Bearing Very Hard to Find $1600
6. Koyo Radiator for Integra- Denso core. Little Beat up. does not leak. had it fall at 100 mph at the track and roughed it up a little bit but doesnt leak. Comes with Slimline Fan $180
7. 2 Brand New OBDII Distributors for b series Vtec. Paid $318 Will take $240 each
