FS:***Going K-Series....B-Series Giveaway***
95 GsR Block
Bored and Honed .20 over (81.5mm)
Line Honed
Balanced and Blueprinted to 10500RPM
ARP Rod Bolts
ARP Head Studs
ARP Flywheel Bolts
ARP Main studs
JE Pistons Custom 12:5:1 CR Pistons (Deburred)
Eagle Rods
ATI Pro Race Damper
All OEM Honda Bearings
New Oem ITR Oil Pump
New Oem ITR Water Pump
ACT Heavy Duty PP
ACT 6-Puck Clutch Disc
ACT Prolite 8lb Flywheel
DC Sport 4-1 Race Header (Heat Coated by Calico Coatings)
prob. forgetting other stuff
$1550obo
95 GsR Cylinder Head (headwork alone costed $2750)
5 Angle Valve Job
Fully CNC Race Ported and Polished
Ferrea Titanium Valves
Ferrea Titanium Retainers
Ferrea Double Valve Springs (able to hold up to .500lift+ camshafts)
Bronze Valve Guides
Hondata IM Gasket
OEM Honda Headgasket
Skunk2 IM Heat Treated by Calico Coatings
RC 440cc Injectors
Skunk2 Stage 3 Camshafts
AEM Tru-Time Cam Gears
$1350obo
95 GsR Transmission
All New Oem Acura Internals
Oem Acura Syncros (heat treated by Calico Coatings)
Oem Jdm ITR LSD
$900obo
OR COMPLETE SWAP CAN BE HAD FOR $3500shipped
**well as i said in the title i found a good deal on a Complete Jdm K20A and that just tickles my pickle cause i have some serious plans for an N/A project with it! anywho enuff about my wet dreams,the motor was professionally built by a Certified Honda/Acura technician of 17yrs and its guarrenteed to not have any problems. this complete setup was dyno tuned on Hondata s200 with a stock GsR exhaust manifold :thumbdown: (didn't get my RMF header yet) and it made 205whp@130ft.lbs at 8500RPM on 93oct.(have dyno sheet to prove)! all tunning was done with no timing or no adjustments of cam gears. the motor has been together now for only 4wks and everything only has 784miles on it since being built. everything was broken in correctly and no corners were cut for this build.***
Prices are not written in stone cause i'm trying to get rid of it but don't lowball because i know how much everything is worth.
also FOR SALE 2000 B16A3 AEBS SLeeved Block
Bored to 84mm,needs to be honed and its ready to go
this is a BARE BLOCK which means no Crank,Rods,or Pistons! Main Caps are included though
$700shipped
**NEW PRICES**
Longblock:$2300shipped
Tranny:$875shipped
Longblock/Tranny: $3000shipped
