EF,EG,and DA teg parts also b-series Swap stuff
here are all the goodies and stock parts i gotta get rid of. I just finished up my boys swap in his EG and i Have yet even more stuff in my garage. Working on pics right now. Anyway here is the list from hell
Open to offers or possible trades
Still have the clutchmasters Stage 3 clutch for probe GT/626/mx6 with 2.5 v6,It has not even made it through the break in yet no TO bearing $180
Z6 and 92-95 civic B-series stuff
1. D16z6 bottom end with spun bearing, needs hone and micro polish Make offer
2. D16Z6 complete Intake mani $60
3. D16z6 Crank pulley with bolt $15
4. New set of NGK blue plug wires $offer
91 Civic Parts
1. sold
2. DX cable trans no grinds $100
3. Almost New set of axles for SI trans, works for DX also $75 for the set
3. D15B2 head with 78,000 miles on it $Best offer
4. DPFI Complete intake mani $20/obo
5. DPFI Disty in great condition $40
6. PM5 ECU for DPFI $10/obo
8. PM6 ECU $40
9. MPFI setup for 88-91 civ/rex have SI complete intake mani, PM6 Ecu and the wiring parts u need for the converion NO DIZZY $Best offer
10.HF intake mani almost bare with TB but no TPS $offer
11. new Napa Starter for d-series cable trans $50
12.sold
13. Stock hatchback corner lights in ok condition $10
15. Blue cargo cover for hatch in good conditon $offer
16. Stock shift linkage with poly bushings $25
17. Stock Guage cluster with 72,000 miles on it $20
18. Throttle cable bracket for b-series swap using stock cable $10
19. Set of indiglo guages for 88-89 SI cluster dead powerinverter$15
20. Brake booster $offer
90 Integra Parts
1. Complete b18 intake manifold $60
2. Bare b18 intake manifold, has some stuff $30
3. Complete AC system minus a couple hoses $Makeoffer
4. another b18 ac compressor $60
5. Pr4 ECU's $30 each
6. complete set of good condition stock b18a motor mounts $50
9. 3X power steering pumps $20 each
11. Teg Manual trans halfshaft $50
12. Stock black steering wheel with cruise control buttons $20
13. 2X b18 wiring harness, have ecu plugs as well
$35 each
14. Complete teg sunroof assembly its all there with wiring $MakeOffer
15. 2x 90 teg guage clusters $30 each
16. NEW Set of MSD 8.5mm wires $40
17. B18a Disty complete $50
18. 2x Speedo cables $offer
20. Stock B18 cam gears have 2 sets $offer
21. 90 teg power mirrors black, p side has busted glass $offer
22. Interior clock $10
22. Blue E-brake console with ashtray $10
23. 3rd brake light $10
24. Multi function Switch (turn signal) have 2 $25 each
25. Wiper motor with delay $offer
26. Set of complete headlight assembly's with corners $80/set
27. Set of tailights ok conditon $50/set
28. Steering colum with ign cylinder and key $offer
29. B18 valve cover needs paint $offer
Open to offers or possible tradesStill have the clutchmasters Stage 3 clutch for probe GT/626/mx6 with 2.5 v6,It has not even made it through the break in yet no TO bearing $180
91 Civic Parts
1. sold
8. PM6 ECU $40
12.sold
90 Integra Parts
$35 each14. Complete teg sunroof assembly its all there with wiring $MakeOffer
i have a few from a 90 integra, i used one to make a whole new clutch line on my boys EG hatch, someone tell me y the use a 10mm fitting line from clutch master cyl to a union connector on the firewall, then its 12mm line from there to the rubber line on slave cyl. I replaced it all with a single 10 mm brake line fit perfect too. anyway let me know if i can help bro
