FS: B-series, B18 engine mounts/brackets, AEM, ARP, Defi, GReddy
Engine Parts
(2pr) B-series VTEC PR3 Cam Gears - $15 shipped/pair
(10) '96-'98 Acura TL Intake Manifold Studs [M8x1.25x50mm] - $8 shipped
.installed, never run, otherwise brand new
(8) GS-R Intake (ITR Exhaust) Inner/Outer Valve Springs - $35 shipped
(1) B-series Timing Belt Tensioner & Bolt - $15 shipped
.used
(1) B-series Rear Main Cover & Seal - $20 shipped
.new seal installed
(8) B-series AT Flexplate Bolts - $15 shipped
(1) '95 Integra GS-R OEM Oil Cooler - $70 shipped
.included: (2) hoses, (4) clamps, (1) through bolt, and (1) o-ring
.good condition
.96k miles
(1) '98 Integra GS-R Main Water Pipe - $15 shipped
.compatible with '98 to '01 GS-R's
(1) OBD-1 P72 Main Water Pipe - $15 shipped
(1) OBD-1 P72 Thermostat Housing - $15 shipped
.from my '95 Integra GS-R
.compatible with '94 to '95 GS-R's
.sold as is seen in picture
.does not include the thermostat cover, thermostat, (2) M6 bolts, or the fan thermoswitch
(1) '95 Integra GS-R Rear Tranny Mount - $15
.slight tear
.part number: 50810-ST7-000
(1) '95 Integra GS-R AC Bracket - $40
.part number: 38930-P72-000
(1) '95 Integra GS-R Upper Tranny Mount - $30
.part number: 50805-SR3-900
(1) '95 Integra GS-R Upper Engine Mount - $40
.part number: 50820-ST7-003
(1) '95 JDM GS-R RHD Engine Wiring Harness - $45 shipped
(1) ITR Crankshaft - $250 shipped
.balanced, oil holes chamfered, journals micropolished
(1) GS-R Crankshaft - $50 shipped
.#1 rod journal needs to be ground to .010" undersized or polished even more
.other journals need to be polished since surface oxidation has formed since the last time I checked it
(4) GS-R Conrods w/ PCTX .25OS Pistons & Piston Rings - $150 shipped
(3) GS-R Conrods - $25 shipped for all three
.97k miles
.all are #3 big-ends
.544g, 546g, 546g
(1) '95 GS-R Differential - $45 shipped
.4.400 final drive ring gear not included
.(10 final drive ring gear bolts not included
.VSS Ring Gear not included
(1) OBD-1 GS-R Lower Timing Belt Cover - $20 shipped
(1) 2.5" Test Pipe - $25 shipped
.2-bolt flange IN / 3-bolt flange OUT
.17" length
.gaskets included
(1) 2.5" Race Pipe [DC2's ONLY] - $85 shipped
.fits: bolts onto DC2 Integra ('94-'01) with JDM ITR header [2.5" collector]
.costs: JHPUSA 2.5" Collector Flange ($25), 3ft of Kteller 2.5" Stainless Steel Piping ($41), Borla 2.5" Stainless Steel Turn-Down ($52), and welding/hanger ($30)
.used a couple times
(1) ITR Cat-back Exhaust w/ Hytech Twin-loop Muffler - $300
.no 2nd resonator
.SMSP Stainless Steel 2.5" transition to cat (to use a 2.5" OUT cat)
.2.5" from the axle back
.it's probably gonna be a pick-up only piece since it's all one piece
(1) SMSP Carsound 2.5" 94066 Catalytic Converter - $145 shipped
.good condition
.used for maybe 8k miles
(1) Perma-cool Sandwich Plate Adapter [M20x1.5] - $15 shipped
.part number:
.used
.requires modification to work with a Honda
(1) AEM Fuel Filter [blue] - $90 shipped
.part number: AVM-25-200B
.replaceable filter element
(1) '95 GS-R Power Steering Pump - $35 shipped
(2) ITR PCV Joint Tube - $5 shipped each
.both unused, one is NIB
(1) OEM Honda '94-'01 Integra Paper Filter - $7 shipped
.slightly used and still good for another 10k miles or so
(1) OEM Honda Block Heater - $25 shipped
.used a couple of times last winter, otherwise new
(1) B18C1 Oil Dipstick - $10 shipped
(1) Defi 60mm BF Boost Gauge [NIB] - $185 shipped
.Open package and the gauge was removed for a test-fit/troubleshoot, and that's all.
(1) LS Fuel Feed Line - $50 shipped
.open package, othewise good as new
(1) OBD-1 P72 ECU - $95 shipped
.from a '95 GS-R
.failed #2 cylinder injector driver
AN Fittings & Adapters
(1) 1/2" NPT to 1/8" NPT Pipe Bushing [aluminum] - $5
.part number: FCM-2141
.retails for $7.99 @ Summit Racing
.new
(1) Accusump Check Valve - $15 shipped
.new, unused
(1) Earl's 1/8" NPT female coupler - $4
.part number: EAR-991001
.NIB
(1) Earl's -10AN to 1/2" NPT Tee on the Run Adapter - $10 shipped
.part number: 982610
.like new, unused
(2) Aeroquip 3/8" NPT to -10AN Flare Adapter [aluminum] - $4 each
.part number: FCM2185
.available at Summit Racing for $6.95
.one new, one used
(6ft) -4AN Nitrous Line - $25 shipped
(1) Autometer 1.5ft -4AN Braided Line - $20 shipped
(1) Aeroquip 3/8" NPT to -4AN Flare Steel Adapter - $3
Other Misc. Parts
(13) Acura CL Open-Ended M12x1.5 Lug Nuts - $20 shipped
(1) '95 Integra Front Lug Stud
.free replacements for whomever has broken any of their's
(8) '95 Integra Rear Lug Studs - make an offer for all or any
.slightly longer than the front lug studs
(1pr) '01 Integra LS Front Shocks - $25 shipped
.sold as is shown in the picture
(2) '95 Integra Front Shock Dust Covers [metal] - $15 shipped
(1) EM Racing DC2 Rear Trunk Bar - $100 shipped
.new and unused
.includes mounting hardware
(1) Integra GS-R ECU Guard Plate - $10 shipped
(1) '95 Integra GS-R Cloth Rear Seats & Trunk Carpet [blk] - $50 + S&H
.good condition
.96k miles
(1) ZIF Socket - $5 shipped
.purchased from moates.net for $10
.high profile (blk)
(2) Rear Wiper Motors - $10 shipped each
(1) Wedge Seat Bracket - $85 shipped
.'94-'01 Integra Driver-side
.new and unused
(1pr) SRR DC2/EG Rear Adj Toe Arms - $80 shipped
.NIB
(1) Integra Spare Tire - $35 shipped
.4x100 lug pattern
.from my '95 GS-R
(2) Tein Standard 14 kg/mm Spring - $75 shipped
.used for about a year total since I don't use the Tein's in the winter season
(2) Tein Standard 16 kg/mm Spring - $75 shipped
.I ordered them and they were too much for me
.used not very much
Tools
(1 set) Generic Flex-joint Sockets - $15 shipped
.includes: 9mm, 10mm, 11mm, 13mm, 15mm, 17mm, 19mm
(1) Earl's AN Fitting Pressure Test Kit - $80 shipped
.part number:
.includes -3AN to -12AN
.never used
(1) Moroso 81.5mm Piston Installation Ring - $20 shipped
.part number: MOR-61902
.never used
.Summit price: $34.99
(1) Mitutoyo Depth Micrometer Set - $200 shipped
(1) Valve Lapping Tool - $5 shipped
(1) Sears Craftsman Beam-type Torque Wrench - $20 shipped
.0 to 75 lb*ft range
.never used
(1) Sears Craftsman Dial-Back Adjustable Timing Gun - $35 shipped
Books
(1) Race Car Aerodynamics (Designing for Speed) - $20 shipped
.author: Joseph Katz
PM me here, IM me at bchang378, or e-mail me at in_vtec@yahoo.com for questions or more pics.
I'm sure I'll dig up parts here and there as I go, so stuff changes all the time as I no longer find a use for them.
Ben
.used
.new seal installed
.good condition
.96k miles
.slight tear
.97k miles
.544g, 546g, 546g
.17" length
.gaskets included
.no 2nd resonator
.good condition
.part number:
.used
.from a '95 GS-R
.new
.new, unused
.NIB
.like new, unused
.one new, one used
Other Misc. Parts
.new and unused
.good condition
.96k miles
.high profile (blk)
.new and unused
.NIB
.4x100 lug pattern
.from my '95 GS-R
.used not very much
Tools
.part number:
.never used
.never used
.never used
Books
Ben
