FS: ca...freeparts..and vtec parts ...need to go
hello people my garage is getting full now so i need to get rid of ALL OF THIS!!!!!!!!!
FREE PARTS!
4 integra rs hubcaps.
4 honda civic sawblade hubcaps...
enigine hoses the two big main ones(from coolant)
front mudflaps...primer..
FOR SALE PARTS:
b16a head complete
emission control solenois.purge control..the 2 solenoids with all those little hoses
map sensor assy
fuel press regulator.
throttle cable.
fuel filter canister..
also the thiung that goes inside the tranny and you plug in the speedo cable and tells you the mph..it has a gear and stuff well i got an extra
2 rear stock shocks
power steering reservoir.
b16a water pump
b16a oil pan almost perfect condition..really good
b16a oil squirters for ls/vtec
b16a good cond crank
b16a flywheel.
b16a clutch with everything..good cond low miles
oil sensor came from the bolck
knock sensor came from the block
and another sensor with 2 little plug ins
and the mounts that holds the intake manifold and has a square canister with hoses...
92 gs-r stock header
b16a jdm exhaust manifold
b18a power steerring pump
b16a power steering pump
obd-1 injector wiring
obd-0 full b16a engine wiring
vtec solenoid green plug.
4 14 inch steelies with worn tires in good condition
b18a oil pump
crank pullie
termostat housing...... thats it send me any offers ...all of this has to go ...for heavier stuff i prefer pick up but if u pay shipping then it's youres....later...boosted99accord@cs.com
FREE PARTS!
FOR SALE PARTS:
b16a head complete
map sensor assy
throttle cable.
2 rear stock shocks
b16a water pump
b16a flywheel.
b18a oil pump
crank pullie
im located in the sd area..escondido exactly...not everything is free ..some parts are free and the other are for sale...to check exactly how much shipping is just put this ..this is my zip code
92061 or to be exactly
275 paradise creek
valley center, ca 92082
275 paradise creek
