Alpine MRP-M350 mono amp AND 10" Woofer
Old Jan 15, 2004 | 10:43 AM
ziggyziggy's Avatar
ziggyziggy
i am asian
Default Alpine MRP-M350 mono amp
This unit has been used for only a month. It was installed underneath the trunk floor where the spare wheel is located. Looks and performs as if it is brand new since nobody and nothing ever came in contact with it.
Price: $89 and free shipping.
DETAILS
Thanks to impressive power output, affordable pricing, and exceptional reliability, Alpine's V-Power amps are consistently among our best-selling models. The MRP-M350 mono amplifier gives you awesome bang for your buck, and sports some "extras" that you'd usually find only on higher-priced amps!
Hook up the MRP-M350 to one 4-ohm sub, and you get 200 watts RMS; connect a second 4-ohm subwoofer and the power output increases to 350 watts! All that juice means that your subs won't just be loud, they'll sound clean and musical, too. A variable low-pass crossover lets you tune the output to match your particular sub setup.
The 15 Hz subsonic filter eliminates very low notes (those that are too low to hear) from your system, so your bass won't sound muddy. Plus, you'll want to take advantage of the BassEQ — an adjustable bass boost of up to 12 dB at 50 Hz! Speaker-level inputs allow you the flexibility to hook up the MRP-M350 to just about any system, and gold-plated terminals ensure that you get clean signal transfer both into and out of the amp.
Key Features:
200 watts RMS x 1 at 4 ohms
350 watts RMS x 1 at 2 ohms
requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
MOSFET power supply
low-pass crossover, 50-200 Hz, 24 dB/octave
variable Bass EQ bass boost (0-12 dB at 50 Hz)
preamp- and speaker-level inputs
blue power LED
extra-large gold-plated terminals
9-3/16"W x 2-7/16"H x 9-9/16"D
1-year warranty
ziggyziggy's Avatar
ziggyziggy
i am asian
Default Alpine Type-R SWR-1041D subwoofer
Used for less than 3 month. Looks and performs in perfect condition.
Price: $80 w/free shipping (this thing is HEAVY)
DETAILS:
Go ahead — crank up that volume knob because Alpine's top-of-the-line 10" subwoofer can definitely take it! The precision-crafted SWR-1041D 10" dual 4-ohm voice coil Type-R sub handles lots of bass power, and still provides the accuracy and crystal-clear sound you expect from Alpine.
The motor structure and double-stacked magnets focus magnetic energy within the vented pole piece for awesome power handling. The pulp cone has been reinforced with Kevlar® (the material used in bulletproof vests) for extra rigidity. A 1" Santoprene rubber surround aids in cone travel while guarding against decay that can mar speaker output. An extended spider landing area provides extra excursion for fuller bass.
The dual 4-ohm, 2" voice coils are big enough to handle up to 1,000 watts of peak power and provide system wiring flexibility. The tinsel leads are woven into the dual progressive Nomex spiders so you don't have to worry about them splitting apart. With this design, you'll get nearly 3" of cone excursion for maximum output. An aluminum diecast frame provides a secure, non-resonant housing.
The SWR-1041D is designed for use in sealed or ported enclosures.
Note: If you are wiring this DVC sub for lower impedance, make sure that your amp is compatible. Most car amplifiers are stable down to 2 ohms in standard mode, or 4 ohms in bridged operation.
Key Features:
Kevlar®-infused pulp cone
frequency response 28-1,000 Hz
power range 100-300 watts RMS
peak power handling 1,000 watts
sensitivity 85 dB
top-mount depth 5-15/16"
sealed box volume: 0.5-0.8 cubic feet
ported box volume: 0.6-1.25 cubic feet
Recommended Box Type: 1, 2, 3
1-year warranty
Old Jan 19, 2004 | 07:24 AM
ziggyziggy's Avatar
ziggyziggy
i am asian
Old Jan 19, 2004 | 07:25 AM
ziggyziggy's Avatar
ziggyziggy
i am asian
Old Jan 19, 2004 | 09:12 PM
ziggyziggy's Avatar
ziggyziggy
i am asian
Old Jan 19, 2004 | 09:13 PM
ziggyziggy's Avatar
ziggyziggy
i am asian
Old Jan 20, 2004 | 12:22 PM
Co0lDood's Avatar
Co0lDood
[ATP]ATL
all i see are girls!
Old Jan 21, 2004 | 11:29 AM
ziggyziggy's Avatar
ziggyziggy
i am asian
girls come with sub
ziggyziggy's Avatar
ziggyziggy
i am asian
Old Jan 22, 2004 | 10:21 PM
ziggyziggy's Avatar
ziggyziggy
i am asian
