2 Brand New Sony Amps FS
Still here... sorta...
Selling 2 Sony Amps (specs below). One has never been mounted, only removed from the box once and the other was mounted and used for two months. They are last year's models, and I'm only asking $175 for both (one amp was $300+ and the other was $235 new - can't beat getting them both for $175!!)
SPECS
THe two channel is a XM - 1902GX
http://www.crutchfield.com/cgi-bin/S...=158XM1902&s=0
Specs:
-760W Max Power (380W x2 @2O )
-150W x2 into 4O , 20-20kHz, at 0.04% THD
-190W x2 into 2O , 20-20kHz, at 0.01% THD
-380W x1 into 4O , 20-20kHz, at 0.01% THD
-Variable 50-300Hz Hi/Lo-pass filter
-Phase Shift Adjustment Control
-MOSFET Power Supply & Outputs
-Line-level and Speaker Level Inputs
-Gold Plated Recess Connectors
The four channel is XM - 754SX
http://www.crutchfield.com/cgi-bin/S...158XM754SX&s=0
Specs:
- 800W max power (400W x2 @4O )
- 75W x4 into 4O , 20-20kHz, at 0.04% THD
- 190W x4 into 2O , 20-20kHz, at 0.01% THD
- 75W x2 +200W into 4O , 20-20kHz, at 0.01% THD
- Variable 50-300Hz Hi/Lo-pass filter
- 40Hz Low Boost (0-10dB)
- High-Current MOSFET Output Stage
- MOSFET Power Supply
- Line-level and Speaker Level Inputs
- Gold Plated Recess Connectors
Send me an EMAIL or just reply for info.
Thanks!!
SPECS
Specs:
Specs:
Thanks!!
LateApex
12-06-2003 07:48 PM
