Adult Toys - December 2007 - New Products For Your Honda
Okada Projects Plasma Direct Coils
Okada Projects (949) 583-7800 www.okadaprojects.com/usaThe Plasma Direct from Okada Projects is an ignition coil with a built-in high-power amplifier. This complete ignition upgrade is intended to increase secondary spark current, generates high-frequency multi spark discharge and is designed to increase horsepower and torque. Installation is easy and involves simply replacing the stock coils with Okada Projects' Plasma Direct Coils. It is not necessary to cut into the stock wirings. It is available for popular Honda applications-K20, K24, F20, F22 and D17 engines.
Injen SP1578 Cold Air Intake
Injen Technology LTD. (866) 944-6536 www.injen.comInjen Technology recently introduced the new SP1578 cold air intake system for the '06-'07 Honda Civic Si coupe and sedan. Featuring Injen's patent pending Mega Ram Technology process, the SP1578 is said to produce up to 11 hp and 12 lb-ft of torque. With the SP1578, lean conditions and check engine lights will be kept safely at bay thanks to the Mega Ram Technology process helping to keep the air/fuel ratio at a factory safe level.
Racing Hart RS-451
Dazz Motorsports (626) 962-0033 www.dazzmotorsports.comRacing Hart introduces its latest wheel, the RS-451, designed with the Honda Fit in mind. The Racing Hart RS-451 features a unique split spoke face and multi-piece construction while conforming to JWL and VIA testing regiments. The RS-451 is available for the Honda Fit in 17x7 and 18x7.5 in a machined black finish. It is suitable for both street and track use.
Blox Racing Billet Throttle Body
Blox Racing (510) 440-1605 www.bloxracing.comBlox Racing billet throttle bodies are currently available for the Honda and Acura D-, B- and H-series engines, with the F-series available soon. Each unit is precision machined from AL6061 and features new brass throttle plates, stiffer throttle springs and sealed bearings for increased airflow, quick response and smooth operation. These high-performance throttle bodies are designed as direct-fit replacements and come in various sizes ranging from 66mm to 76mm openings. Hardware is included and reuses the stock sensors and throttle cable.
Works Bell Rapfix
Works Bell USA (626) 618-1100 www.worksbellusa.comWorks Bell Japan introduced a new line of steering wheel accessories, including steering hub adaptors and quick releases. The Rapfix Ball Lock System is constructed of dropforged aluminum and other quality materials. Also available for the Rapfix is a key-lock system to prevent unwanted use or theft. This line of accessories is suitable for many applications on both the show floor and racetrack. Works Bell products are available in the USA through A Spec Products.
Mobile Office Extension Vehicle Computer Mount
Rissler R & D, Inc.(253) 862-8795 www.rissler-rd.comThe MOE is suitable for enthusiasts monitoring their performance and system managements on their laptops. It is a temporary vehicle computer mount, securely holding a laptop or other electronics into any vehicle, while still being fully removable. The cradle holds a laptop and the base provides flexible attachment options for each vehicle type. The cradle can be configured for most laptop brands with screens ranging from 12 to 21 inches. Components are built of non-metallic materials and fit in travel luggage.
Synapse Engineering Synchronic Blow Off ValveSynapse Engineering
www.synapseengineering.comThe new Synchronic blow off valve does not use a diaphragm and is designed to offer increased response with no compressor surge. It features a pull-type piston actuated design and poppet valve for maximum flow at initial opening. The valve includes a stainless steel weld on flange, with other flange options available separately. For cars with mass airflow sensors discharging into the atmosphere, an anti-stall valve kit is also available separately.
JIC J-Force 05
JIC (562) 803-6122 www.jic-magic.comJIC has a new high-performance wheel, the J-Force 05. Made in Japan, the J-Force 05 features a clean five-spoke design, high-quality finish, high-pad clearance for big brake applications and staggered wheel widths for a high-performance vehicle. The J-Force 05 wheel also includes a JIC emblem and JIC centercap to show that your vehicle is equipped with a genuine JIC product. Valve stem and cap are also included with each wheel. It is currently available in silver, Aluminite Black and Glittering Black.
Weapon-R X-Cross Strut Bar
Weapon-R (650) 877-8280 www.weapon-r.comThe X-Cross strut bars from Weapon-R were designed to minimize body roll from the car. Custom-made for each application, they mount to the OEM strut mounts and triangulate the rear of the car. Made of billet 7075 aluminum to ensure strength, weight savings and durability, this rear strut bar ties the most rigid points of the car together. The strut mounts are CNC machined and then TIG-welded for strength and finally polished to a show quality shine. It is available for many of the popular applications.
Photo Gallery: New Products For Your Honda - December 2007 Adult Toys - Honda Tuning Magazine
Read More | Digg It | Add to del.icio.us
More...
Okada Projects Plasma Direct Coils Okada Projects (949) 583-7800 www.okadaprojects.com/usaThe Plasma Direct from Okada Projects is an ignition coil with a built-in high-power amplifier. This complete ignition upgrade is intended to increase secondary spark current, generates high-frequency multi spark discharge and is designed to increase horsepower and torque. Installation is easy and involves simply replacing the stock coils with Okada Projects' Plasma Direct Coils. It is not necessary to cut into the stock wirings. It is available for popular Honda applications-K20, K24, F20, F22 and D17 engines.
Racing Hart RS-451
Works Bell Rapfix
JIC J-Force 05
More...
