2006 Porsche 911 (997) Turbo spy shots
It won't officially debut until September, but we have the best pictures yet of the 2007 Porsche 911 Turbo. Caught for the first time undergoing road testing in the U.S., our spy photos reveal a 911 Turbo with a new set of slim intercooler intakes that look as though they'll make their way to the production model.
The roughness of this prototype's bodywork indicates that many of the details are still hidden, but look past the obvious disguise and the car's major hard points are well defined. The wider tail section not only blends with the new intakes, it also makes way for what will probably be a set of 19-inch wheels wrapped with tires in the 315/30 range.
When it does debut at the Frankfurt Motor Show in September, the 2007 911 Turbo is expected to use the larger 3.8-liter flat six found in the current Carrera. With the extra displacement the new Turbo may push into the 460-480-horsepower range with a corresponding increase in torque. Like the current Turbo the next-generation model will come standard with a six-speed manual, but a DSG-type transmission is said to be in the works.
Despite all of these changes, the 2007 Porsche 911 Turbo will not weigh substantially more than the current version, which goes a long way to pushing the vehicle's top speed past the 191-mph mark. Like the latest Z06 Corvette, the 911 Turbo is expected to accelerate from zero to 60 in less than 4 seconds. Some rivalries never get old.
http://www.edmunds.com/insideline/do...cleId=106272#5
Some of the cladding comes off...
According to The Car Connection, these pics show "the production scoops, spoiler, rear bumper, exhaust tips, side marker lights, and more." I guess by scoops they mean the ones on the sides of the rear bumper.
As for the front bumper, headlamps, and air scoops on the leading edges of the rear fenders, I guess we'll just have to wait and see.
Off with the cladding! Well, most of it.
Our spies have undermined Porsche’s plan to keep its seventh-generation 911 Turbo secret until its world premiere at the Geneva motor show next February.
Shown here, devoid of bulky camouflage, blackout paint and taped disguise, is the turbocharged version of the new 997 as it will appear on American highways by next June. We caught the production-ready prototype as it ventured out of Porsche’s factory gates for final shakedown tests. The photos reveal a curvaceous appearance and eye-catching details that are bound to set Zuffenhausen’s latest performance leader apart from tamer versions of the 911.
Building on the wide-bodied appearance of the recently introduced 4S, the 997-series Turbo declares itself with a unique front bumper carrying high-intensity LED indicators and parking lights integrated into a horizontal bar running across the outer air ducts. The fog lamps are set low on the corners within special housings designed to protect them from stone damage.
Along the flanks, sills under the doors are more pronounced and sizeable air ducts ahead of the rear wheel arches provide efficient cooling. Changes to the rear include the adoption of a reshaped biplane wing assembly that Porsche says will provide added levels of downforce, and a bumper with small ducts to pull hot air out of the engine bay. Completing the makeover, lightweight 19-inch alloy wheels wear ultra-low-profile tires, accentuating a significantly lower ride height than standard 911 models.
Behind the Turbo’s distinctive look is a more powerful version of Porsche’s twin-turbocharged 3.6-liter six-cylinder engine. High-level Zuffenhausen sources say the powerplant is derived from the outgoing model’s engine, which itself evolved from Porsche’s Le Mans-winning 911 GT1 sports car program.
We’ve heard reports of power outputs of up to 500 hp—a massive 80-hp or 19 percent increase above the outgoing model’s 420 hp. The company’s habit of incremental improvement suggests the figure could be significantly lower, though with others advertising 500 hp, Porsche must be tempted to respond. Nothing is official just yet, but we’re told to expect a subtle 30-hp gain, taking the new model up to 450 hp (the same power obtainable by adding a Porsche X50 power kit to today’s 911 Turbo S—perhaps a similar option will be offered on the new model)
The Turbo’s torque figure also rises by about 30 lb-ft to 457 lb-ft. Drive goes to all four wheels via a standard six-speed manual unit or a new double-clutch automatic gearbox, and Porsche’s familiar full-time awd system.
Key to the increased output is Variable Turbine Geometry technology for the two turbochargers. Common on high-performance diesel engines, VTG continuously adjusts the angle of the turbocharger’s vanes to provide a more linear delivery of power and wider spread of torque. To make this work on gasoline engines, with much higher exhaust temperatures than diesel units, the BorgWarner-developed turbos employ heat-resistant ceramics. The engine also benefits from improved variable intake and exhaust valve timing.
As already reported by AutoWeek (“Porsche Juices the 911,” Nov. 7), the 997 Turbo’s weight is up to about 3520 pounds. Even with the added weight, the 997 Turbo gains in power-to-weight ratio and should be able to hit 60 mph in well under 4.0 seconds with a top speed of 190 mph.
http://www.autoweek.com/apps/pbcs.dl...024/LATESTNEWS
