2005 Corvette C6
That's Dirté
![Default](https://www.honda-acura.net/forums/images/icons/icon1.gif)
Originally posted by KRA
i love the rims... i like them better than whats on the current vettes
the 97-99 wagon wheel rims, i do not like. maybe i'll like the late c6 rims...
lots and lots of fail
1 Post
Uh some of the GMI specs are off heres the actual specs:
RPO List:
AAB Memory Package
AG2 Seat adjuster, power, front passenger 6-way
AJ7 Air bags, frontal and side impact, driver and front passenger
AK5 Air bags, dual-stage, frontal
AQ9 Seats, front Sport bucket
AR9 Seats, front bucket
C2L Roof Package
CC3 Roof panel, removable
CF7 Roof panel, removable, 1-piece, body-color
CJ2 Air conditioning, dual-zone, automatic
CM7 Convertible top, power folding
D42 Luggage shade
DD0 Mirrors, inside rearview with compass and driver outside rearview
DL8 Mirrors, outside rearview, power, heated, body-color
F55 Magnetic Selective Ride Control
FE1 Suspension, 4-wheel independent
FE9 Emissions, Federal requirements
G90 Axle, 3.15 performance ratio
GU2 Axle, 2.73 ratio
GU6 Axle, 3.42 ratio
K11 Air filtration, includes pollen filter
KA1 Seats, heated
LS2 Engine, 6.0L LS2 V8 SFI
MN6 Transmission, 6-speed manual
MX0 Transmission, 4-speed automatic
N37 Steering column, power telescopic
NB8 Emissions override, California, Massachusetts, New York or Vermont
NC7 Emissions override, Federal
NE1 Emissions, Maine, Massachusetts, New York or Vermont state requirements
NK4 Steering wheel, leather-wrapped
QG6 Wheels, 5-spoke aluminum
QG7 Wheels, polished
R8C Corvette Museum Delivery
U2K Sound system feature, XM Satellite Radio
U3U Sound system with Navigation, ETR AM/FM stereo with CD player and MP3 playback
U52 Instrumentation, analog
UE1 OnStar
UG1 Homelink transmitter,
US8 Sound system, ETR AM/FM stereo with CD player and MP3 playback
US9 Sound system, ETR AM/FM stereo with 6-disc
UV6 Head-Up Display
VK3 License plate bracket, front
YF5 Emissions, California state requirements
Z51 Performance Handling Package
Trim Levels
Coupe -1YY07
"Base" 1SX
1SA
1SB
Convertible-1YY67
1SA
1SB
SOME DETAILS
Are there any transmission options? - Just Manual or Automatic
Is the manual transmission a Tremec T-56? YES
Is the base AT a 4L65-E?-YES
Axle, 2.73 ratio, limited slip
1 - Standard with (MX0) Transmission, 4-speed automatic.
1 - Only available with (MX0) Transmission, 4-speed automatic.
Axle, 3.42 ratio, limited slip
1 - Standard with (MN6) Transmission, 6-speed manual.
Tires, front P245/40ZR18, extended mobility, Eagle F1
Tires, rear P285/35ZR19, extended mobility, Eagle F1
Wheels, 5-spoke aluminum, 18" x 8.5" (45.7 cm x 21.6 cm), front and 19" x 10.0" (48.3 cm x 25.4 cm), rear
Wheels, polished, 5-spoke aluminum, 18" x 8.5" (45.7 cm x 21.6 cm), front and 19" x 10.0" (48.3 cm x 25.4 cm), rear
Performance Handling Package, performance-oriented package for the Gymkhana/Autocross enthusiast, includes power steering, engine oil and transmission coolers, stiffer springs and stabilizer bars, specific shock absorbers, larger brakes with cross-drilled rotors, specific tires and performance gearing, Z51-specific, 6-speed manual transmission or performance axle ratio with automatic transmission
Active Handling?? -- YES, standard
Is there a next-Gen Active handling being used? - Just says Active Handling
Magnetic Ride? Option, not standard
CM7 Convertible top, power folding, includes glass rear window with integral defogger
Convertible top, manual folding, includes glass rear window with integral defogger
Roof Package, includes (CF7) Roof panel, 1-piece, body-color and (CC3) Roof panel, 1-piece, transparent
Front plate bracket - YES
Headlamps, bi-functional high-intensity discharge, includes automatic exterior lamp control
Keyless Access, with push-button start, includes 2 remote transmitters which enable automatic door unlock and open by touching door switch
Power Tilt and Telescopic steering wheel?? Power Telescope
Sound system with Navigation, ETR AM/FM stereo with CD player and MP3 playback, (U65) Sound system feature, Bose premium 7-speaker system, DVD navigation with GPS, 6.5" LCD color display touch screen, voice recognition, includes Radio Data System, seek-and-scan, digital clock, auto-tone control, automatic volume and TheftLock
CD Changer?? - YES, 6 disk in dash option
OnStar? - YES
XM Radio? - YES
Compass? - would be in the Navigation system...
Homelink Garage Door Opener?? YES
Head-Up Display, includes dot-matrix readouts for street mode, track mode with g-meter, vehicle speed, engine rpm, and readings from key gauges including water temperature, oil pressure and fuel levels
Seats, heated, driver and passenger
Sport seats - an option
Is there a cloth seat option or are they all going to be leather?- Leather
Console, floor, lockable, includes 2 covered cupholders, ashtray with cigar lighter, auxiliary power outlet and CD storage
Memory? - memory everything is just a given..
Air bags, frontal and side impact, driver and front passenger (standard on everything but the super base coupe - or - I believe that on the 'vert both front and sides are standard, but on the coupe the side ones are optional.)
Cargo area shade - YES
Alarm System?? - Same old GM one
From what I can see, it seems like there is an equipment level on the coupe called 1SX. You can't order many options on that equipment level at all, and it's just labeled as "base". I'm assuming its a low cost, no frills car??
10U Arctic White
19U LeMans Blue Metallic1(premium extra cost color)
27U Precision Red
41U Black
67U Machine Silver Metallic
71U Daytona Sunset Orange Metallic
79U Millennium Yellow (Extra cost color)
86U Magnetic Red Metallic II
Interior colors
- Ebony
- Cobalt Red
- Steel Gray
- Cashmere
Speakers in the seats - Not sure, although I suspect they are
Bluetooth capability? - DON'T KNOW
Are there any engine options?-NO
Is the rear hatch polycarbonate? - NO
Is there a magnesium wheel option? - NO
Is the hood carbon fiber - even as an option? - NO
Is the exhaust made of titanium? - NO
Radio controls on steering wheel? - NO
Paddle shift? - NO
Adaptive Cruise Control?? - NO
Nightvision?? - NO
Rain Sensing Windshield Wipers??- Doesn't seem like it
Cassette player? - Doesn't look like there is
Body Side Moldings are DEAD
Nothing on frame material..
Sorry, no more Torch Red
Sorry, no purple
source: http://palmeter.com/CorvetteTimelineW11P06a.htm
- from corvettforum.com member Zane Merva
RPO List:
AAB Memory Package
C2L Roof Package
D42 Luggage shade
KA1 Seats, heated
UE1 OnStar
UV6 Head-Up Display
Trim Levels
Coupe -1YY07
"Base" 1SX
1SA
1SB
Convertible-1YY67
1SA
1SB
SOME DETAILS
OnStar? - YES
XM Radio? - YES
10U Arctic White
27U Precision Red
41U Black
Interior colors
- Ebony
- Cobalt Red
- Steel Gray
- Cashmere
Paddle shift? - NO
Nightvision?? - NO
Sorry, no purple
Wannabe yuppie
Hmm...is it available as a pure hardtop? It says something about a "roof package" including both a body color and glass roof panel. On the C5 the body color panel was standard and the glass panel was an option.
If that's the case I'd take a hardtop 6-speed with the 3.42:1 rear axle and Z51 package and not too many pointless frills.
Originally posted by rb6teg
I want to see the interior more than anything.....that was the one thing that sucked hard on the C5 corvette.
I don't think that is going to change :chuckles:
'00 Dakar Bus CRS Edition
LCD Squad #0001
LCD Squad #0001
Originally posted by SilverTransAm
i think you're wrong
do you have any information to back yourself up and are you just disagreeing with me just for the sake?
looking at chevys record for the past 3 corvette models, the interior I seriously doubt will improve.
LCD Squad #0001
LCD Squad #0001
